Hey Lads
As stated my RB20DET Onevia isnt in the best of health at the moment. For some reason the car will not rev above about 3000rpm or so (well when it starts to build up some boost)... Car was running fine for about 200km's after I took delivery of it. But all of a sudden it just lost all power and feeling through the pedal and sounded like it was hitting the rev limiter (although only at 3000rpm)
So I have had all pipes checked and some replaced, I had the intercooler replaced, the fuel pump is fine, the injectors and gaps are fine. So the only thing I have been suggested to check is coil packs. Possibility?
Cheers
Chris
Advanced Motorsports
https://www.sau.com.au/forums/topic/123976-rb20det-onevia-its-sick/
sounds like its in 'limp home mode' happened to my car a while back
the ecu isn't receiving a signal from a sensor so it doesn't allow the engine to rev past 3000 to protect it
on my car it was a faulty afm, check all our sensors (o2, afm, aav, etc) an ecu diagnostic will tell you exactly.
My 2 cents
Cheers Mate. AFM was replaced about 2 months ago...
Thing is it will rev past 3000rpm... but only if your not booting it. 3000rpm is all it will go up to with the foot flat, because it wont let it rev once it starts to make boost. If that makes sense?
sounds like afm? was it replaced with a new item, or 2nd hand one?
better try a nissan consult I reckon.......
Ahh so u do step out of the Stagea section hey? :)
Well the standard one died and was re-built.
It hasnt been re-calibrated yet though. So you think it may be that then?
yeah, I do actually.... mind you Im pretty clueless tho.
Id suggest that the afm isnt able to read the large volumes of air being sucked in by that dinkydi Onevia of yours. hence rich and retard.
How is the fuel economy? ratshit?
Nup economy isnt that bad at all... Which is the strange thing. I think its too quick for rich & retard. Although wouldnt it be spilling black smoke out the rear from excess richness if that were the case?
well it could possibly be coil packs. Would make for an easy solution. Pedal looses all feeling at around the 3000rpm mark when the foot is to the floor... So I'm not too sure. Will talk to you about it more on msn
Mate I know everyone else has suggested AFM but I had the exact same problem in my R32 with RB20DET it would cough and splutter at about 3k RPM and putting the foot flat to the floor would do nothing then all of a sudden it would surge back to life it turned out to be my AFM so yeah it seems likely this could be your problem too.
I'm thinking AFM too... This is a re-built one as the old one failed for some unknown reason. Hasnt been re-calibrated yet. Car is at a mechanics today getting a blue slip done. I'll get them to check the AFM for me
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
    • That's incorrect. We have 4 seasons, consisting of pre winter, winter, post winter and a small glimpse of hope!
