  • Replies 52
Posted Images
mmm im hoping its not that :D How much did your's cost to re-do the oil seal on it? Or did ya just replace the turbo
Turbo had about 15,000kms on it from rebuild and seemed like new, just seems odd to be that...
Edited by jazza08
I had this problem with my car. it ended up being the bottom end :D its weird and it would blow HEAPS of white smoke on idle yes ??
Did this happen as soon as you turned the car on ? or only after you got it tuned ?
hi mate, my r33 started bowing puffs of pure white smoke at high rpm which progressively got worse till it blew smoke all the time and at idle.It ended up being two pistons which had cracked on the side letting oil in.
$900 for a new core for the HKS 3040
Its nothing to do with the motor as it started when the new turbo was installed by a mate who im starting to think didn't know what he was doing... i asked about the oil restrictor in the turbo line and he wasn't too sure what i was talking about, maybe the turbos b/bearings are being flooded by oil!
Will find it out tomorrow/friday when the turbo's taken off and the lines are checked.
GCG quoted me around $550 for a new oil seal in the turbo, more money >_< lol
I'd be double checking the oil venting issue.
You know the hoses to the can were to restrictive before, but now with nice big ones you still have the problem? How about you remove them all and go for a little run.
Then stop and open the bonnet and see if its smoking like a chimney. Its worth checking just incase its your rings. Done a comp test?
Is this a new turbo because the old one let go?
Compression is 150 even across all 6 cylinders as of 3 weeks ago.
The old turbo had a problem with the bearing so yes thats why i changed it! As i said i had zero problems (smoke wise, bearing on old turbs was rather loud lol) before this turbo went on, the new catch can deals fine with ne blow by the engine may have.
The turbo was bought from someone i trust and is very well known on the forums which is why im not convinced its somethin to do with the actual turbo itself, plus by looking at it and checking shaft play the turbo appears to be near new.
I am having the oil lines looked at, the one to the turbo to check if it has a restriction piece in it and to make sure the oil return to the sump is not blocked and all is hooked up correctly, as i said the person who did it told me they knew what they were doing but now it appears they're abit iffy on some issues... it was probably installed incorrectly >_<
Just for reference here is pictures of the catch can, the smoke has nothing to do with this set up.
I ran the car with the old set up and it produced more smoke, then ran it without anything on the head and it reduced smoke, with this in place its the same as with nothing on the head (ie no restrictions)!
Plz not outlets are all blocked except lines to catch can which is why i needed a breather in the system >_<
For those who have watched the thread,
The turbo was taken off today and had no restrictor on the turbo's oil line so it was flooding the b/bearings with oil hints the smoke in the exhaust.
So fingers crossed a restrictor on the turbo stops the oil smoke, will find out either tomorrow or monday :wave:
So fingers crossed a restrictor on the turbo stops the oil smoke, will find out either tomorrow or monday :thumbsup:
That will definitely be your problem then.
Just realise that your whole exhaust system and muffler is probably now full of black oily residue. Expect to still see some smoke for a day or two at full throttle. That will quickly go away.
So don't get a fright when you see some more smoke first time you drive the car !!
I got a call today that said they did find a 1.3mm restrictor in the oil line... so unfortunatly its back to square one.
There is some oil in the intercooler piping from when the catch can set up was without a breather which is being cleaned out now however that its been suggested once again its the turbo seal.
Once the car is dyno tuned if its still smoking after a week or so i will get it taken off (for about the 3rd time!!!) and have the turbo pulled apart and replace the oil seal on it as they told me the turbo appears to look good from the outside but you can't know unless you open it up.
I was so excited aswell :yes: lol
Edited by jazza08
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
