"Rich and Retard" is simply the higher air flow/load cells having no ignition timing in them, and the fuel cells at this load are rich.
That is why it cuts, no timing in those load cells.
If you could remap the ecu to put some extra ignition timing in those load cells, you wouldn't have a rich and retard situation.
The TI monitor is more then likely a signal for a trip computer to calculate show current fuel usage.
Also the lack of the throttle switch input, will not matter as the RB25 PowerFC uses the throttle position sensor, not switch. (So it won't matter that its not there.)
From what you have found Cubes, all you have to do is reverse pins 112 & 114 and cut 57 to be safe. (I doubt this pin is connected in the PowerFC though?)
Interesting, well as soon as I find out if my pfc is fried or not I'll throw an rb25 pfc in to it.
Seems almost too easy.
kwazza11, Can I ask you if you did the install your self or had some one else do it. I know you did said 'you' switched the two inj. outputs on the loom. Just to double check it was indeed you who did the work as then I know your not leaving something out. :whistling:
  • Replies 78
I had a look at Bl4ck32's PFC this morning, it too has the little cut disabling ecu pin 57.
So it appears AP Engineering do indeed use one of the rb25 revisions (possibly an early one as the ap engineering pfc uses the early hand controllers) swap the two injector outputs and disable the pin 57.
Cubes, yep i installed it myself and all i did was swap the two injector wires around, the throttle switch is only used for kick-down on autos and the exhaust temp signal (57) i assume is used for the exhaust temp light to indicate a blocked cat, thats been disconnected. everything else has been explained, Ti monitor for trip computer, boost control etc.
was a massively simple exercise, plugged it in, drove it to the tuner's workshop, got it tuned, drive away! :)
Actually I think pin 54 is a throttle closed switch which the RB20 ECU uses to go into idle mode. The throttle sensor box thingy also contains a WOT (probably closer to 75%) switch that from what I can remember is connected to the auto trans and not used by the ecu.
However if the RB25 ecu doesn't need that exact throttle closed signal to determine when it should be idling, then I can't see a problem leaving it disconnected.
The mosfets were fine however the capacitors and resistors had been fried, I did pick some of the tinny little resistors that can hardly been seen were replaced.
All capacitors were replaced as well as resistors. He said I was 'very' lucky. :nyaanyaa:
A few pics of before and after.
Anybody know what the external memory expansion socket/pins are for?
the newer powefcs have a white connector on the board for rom flash upgrades. no idea what the memory expansion is for.
i would expect djetro and pro versions have simply different firmware as they are just code logic changes, wouldnt think it would need more memory or extra chips? seems logical anyway
tops that you got it fixed, is the tune still present ?
damn lucky and cheap to fix might i add, good stuff
Reverse polarity...
How would this affect what you are stating above..
I must admit when I asked how were the mosfets he did say 'suprisingly fine'.
I dont think reverse polarity would be the issue, im not really familiar with the story of yours failing.
Vibration or excessive PCB flexing tend to be a big cause of failures in things like car amps.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
