  • Replies 128
Posted Images
Well :laugh: got the damn car!! finally. im bringing it in to rego and race oace after that. changrd the filter element with K&N drop in replacement tonite before my bro and i took it for a spin. :happy:
heheh u had fub with it last night!!! will try to post some pics later on. BTW wheres the damn height adjuster for the headlights located at?
Edited by stasis
As you all know i got the car today. I noticed the put on the rims back to front. So i took it to a tyre place for an alignment after the wheels have been swapped from front to back. The camber on the passenger side was way off compared to the drivers side. funnu they couldnt match the camber for both sides they came very close though. I think onedrivers side is 1.75 and the other is1.25 or something. What should the setting be. The car is sitting 350mm front and back from center wheel to the arches.
second thing have you guys heard of a suspension called JECS? cos thats what it is on the car noe and thats all i can make out from.
couple of other issues ocasinally the car will auto lick itself (doors)
Keyless entry works find but cannot disable the larm. after opening the doors via key or remote and i dont put in the key to the ignition the alarms go off. So probably i need a wiriing diag. (anybody knows where i can get one? originals of course if i can).
other than that its find. Ben from Race pace inspected the car and everything seems to be allrtie . Had the car on the hoist and everything. other than that everything is allrtie at the moment.
my opinion, get rid of whatever dodgy alarm is in and get a decent one installed. auto lock is usually because you disarm the car but don't open the door, it assume it was a mistake and locks again.
yea i know but this one got a paging system to it. probably i will leave it ad it is first other than that it wirks fine the alarm works fine.
another thing i forgot that its got a turbo timer in it as well. but sometimes it works sometimes dont. o dpmt knw wheter it works on the oil temp or not. might have to get an autp elec to check it out.
my father is an auto electrician, they have people coming in all the time with dodgy alarms, they usually end up leaving with massive bills, so you are probably better off just putting up with it or getting a new one installed
yea probably i will put up with it first its not a main priority.
ok i was just wondering does the 260rs suppose to have a switch that controls 2wd or 4wd? Also are they suppose to have the head light height adjustments? cos mine doesnt have any of them.
Isn't the headlight adjustment thing just a little screw and you use a phillips??
tighten it and the headlights shine down, loosen it and they shine upwards??
S2's with xenon headlights actually have (might have been optional not sure) an electrical headlight adjustment, so you can adjust them up and down, something to do with carrying extra weight, and because the xenons are so bright, you can adjust them down.
the only adjustment you can make to the torque split is a button located to the left of the steering wheel just above the handbrake on the rs4 so maybe look in the same place on your 260 although your handbrake isnt there its in the centre console
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
