hahaha.
I love it how the guys say it's a mix of 50% leather 50% plastic. I said to them leather is not like cake mix ingredient. You can't just mix it with plastic.
Their thing is totally synthetic. It's not '50% leather'.
But yeah, if it gets down to 400, i would seriously consider it if I didn't have to pay $50 postage on top.
but is that with the wrinkle too? probably not. so it's more like 400+50 postage+50 wrinkle, which ends up being $500. not so cheap anymore.
  • Replies 48
hahaha.
i never said 50 % leather 50% plastic...i said it was vinyl that looks and feels like leather...
and i highly doubt the other stuff is leather, in fact i would be suprised if its any different...and for $350 if you can get wrinkle and include postage i would buy a few for myself in diff colours...anyway nuff said.
by the way sorry to whore your thread warren, but i just cant stand people talking shit.
no worries mate..
i know you're just excited because you are going to get yourself a set of these :/
i am excited mate every since i went to ultimate trim last week...
i am just trying to save couple hundred bux for myself and others by organising this group buy...and i have visited few other auto trimmers in melbourne and i know how much real leather is compared to this product and i know there is no way anyone can do real leather for 350 delievered...
i just hope mine looks as hott as yours dude.. :O
Hey mate, they look HOT. Nice buy.
Hypothetically speaking, lets say someone knows someone who owns a leather factory overseas. How could they obtain the exact measurements required, for say, an R32 GTR or R34 GT-T? If only i could get exact numbers!
PS.
My uncle owns a leather factory in Pakistan. :thumbsup:
given my mechanical knowledge which is about medium and my availability of tools which is pretty low, i would say it was a 3/10
tools required:
ratchet with 14mm and 10mm heads
phillips-head screwdriver
crowbar (to remove back seat easily)
Remove 4 bolts per front seat
Place covers over bottom of front seats and secure
Slide covers over top and secure
Slide over top of headrests and secure
Remove back seat. 2 clips under bottom, 2 bolts for back
Place covers over and secure
Reverse the above to re-install
The hardest thing is sliding the cover over the top of the front seats as its a tight fit
the guy is my friend, if you came to melbourne auto showoff you'd noticed my car(white r33 gts-t) as model car :D
i'll put some picture tomorrow if you dont mind
hey man i went to th auto showoff your car was next to the honda with tan "leather" yours had black and white? il post some if you want hehehe
i tripped out because your car looked very similar to mine, i think it was the only white r33 there
not sure of the code
they called the colour "ivory"
its darker than white, but lighter than the cream
I think the color code was M012. Have a look on the Ebay link at the top there is a chart of colors that you can choose from.
tools required:
Thanks, should help when I come to install mine.
ha ha you like the gear knob? i haven't seen ANY auto's with aftermarket gear knobs and i have no idea why! i bought mine for $50 from ebay
it ws easy to make up the switch actually.. the hardest part was getting the old gear knob off - required quite a bit of modification eg cutting things off
There's 2 wires that run to the gear knob. When not connected, O/D is on. When they are connected this turns the overdrive off. I think its designed that way so that you can not accidentally lose O/D ifthe wire gets cut somewhere accidentally...
So i just made a switch and connected the 2 wires to the switch. When the switch is off, the O/D is on, and vise versa
Warren.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
