Has anyone in Vic done any mods to their GTR gearbox? I busted 3rd synchro on the weekend :( and am trying to find out what is the best thing to do while I have the box out?
Labour won't cost me so I will save there but I do need a clutch also, so buying a dog gearset is most likely out of the question, just too much $$$$ at once to spend.
Has anyone heard of stronger aftermarket synchro's??? Where?
Thanks.
https://www.sau.com.au/forums/topic/124960-gtr-gearbox/
all he did was buy leewangs spare GTR box lol.
whats the budget?
No real budget as yet. Just trying to see what is good value for money. I haven't even decided which clutch to go for. Tossing up between OS twin or Exeddy Twin.
I think I will most likely just replace synchros in 2nd, 3rd and 4th. Was thinking of getting short shifter, but have heard bad stories.
https://www.sau.com.au/forums/topic/124960-gtr-gearbox/#findComment-2306663
clutch - http://www.skylinesaustralia.com/forums/in...p?showforum=146
Ring him and discuss pricing vs what you want.
Just have the box rebuilt for stock if you ask me.
Unless your over 400rwkw i wouldnt be worrying about gearsets or anything
https://www.sau.com.au/forums/topic/124960-gtr-gearbox/#findComment-2306833
Thanks for that. I will give him a call. Though I'm a bit reluctant to use another single plate... The Exeddy 3 puck I have was pretty hopless, slipped from day one.
The reason I would like an aftermarket gearset is not the strength but the fact that they are closer ratios.
https://www.sau.com.au/forums/topic/124960-gtr-gearbox/#findComment-2306952
Jim is the man. Trust me >_<
As for ratio's... just change the diff's to 32 GTR diffs :ermm:
Cool will give Jim a call. As for the diff I have just fully rebuilt the rear so I won't be getting rid of that anytime soon :D
Anyone run a short shifter in a GTR? What do you think of it for the track?
https://www.sau.com.au/forums/topic/124960-gtr-gearbox/#findComment-2307319
Jim Berry clutches are the shinitz. No doubt about it. JB FTW!!!
As for the gearbox, if you are running <400rwkw, stock box is fine. After that, I highly recommend the OS Giken Cross Mission gearset. Get the sandwhich billet plate and upgraded input shaft for peace of mind.
This combination in my car has held 600+ awkw with no problems whatsoever.
https://www.sau.com.au/forums/topic/124960-gtr-gearbox/#findComment-2307502
or your a shit driver :D:D
Breaking gears due to excessive power and wearing a syncrho ring out are two differant things. As I have mentioned previously, I am considering an after market gearset not for the strength reason but for the better response the shorter ratios give .eg mines car has R33 diff and aftermarket gearset.
As for Jim Berry, looks like he is the man by an overwhelming number.
Thanks guys much appreciated. :D
https://www.sau.com.au/forums/topic/124960-gtr-gearbox/#findComment-2308121
my comment wasnt directed at you :D
https://www.sau.com.au/forums/topic/124960-gtr-gearbox/#findComment-2308145
I've contemplated it in the long run, but I always figured just whcking in stock boxes was the way to go... but I guess it depends on how big the trail of stock boxes behind you gets...
Thats true, but apart fom the strength aspect of the OS gearset, the added respone you get from the closer ratios is awesome.
I've seen a GTR with the trust gearset and that thing got from 1st to 3rd in no time :D
https://www.sau.com.au/forums/topic/124960-gtr-gearbox/#findComment-2309600
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
