  • Replies 640
Posted Images
I will have blue triangles for everyone.
That extinguisher mount looks ok. If you pull it in any direction does it move or come out?
Thanks Shaun.
Wil - doubt a cold change. Everyone, particularly the flaggies, don't forget a hat, sunnies and suncream. Important. Maybe a big bottle of water too.
Jon - you know what to do... hehe.. be there. :D
Well... its official... i hate my printer and my fax... neither will work.
I have emailed craig, got my number and my group, but I still need to take a form to him tomorrow. Is it possible to get somebody to bring me in a blank form?
Christian
Ok you bunch of lucky bastards, you all better have photos at the end of the day :) I am getting majorly depressed with not being able to drive or flag
Oh well, there's always next time whereever that might be.......Enjoy all
Wow... I totally forgot about this day... man time sneaks up on you...
I'll be there though... and so will Chris Eastern in his R31... should kick arse!
Looking forward to it... but unfortunatly I won't have the semi-slicks I was gonna grab... never mind.
See you in the morning,
Dan.
Just left the track and got home..
Wow.. hot day.. till the wind came through..
Also - for anyone that didn't go.. look at what you missed out..
I'll let one of the other guys fill in what happened.. but looks like a fuel or oil fire on an RX-7 SIII caused the following..
this was just after the car went BOOOMM!!!
always heard rotaries weren't too relaible :whistling:.. sorry to see this happen though..
This is what was left.. although everyone tried to put it out (ando and a couple of other guys) there was little they could do as the fuel tank went up while they were standing 2m away using a fire extinguisher on it..
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
