  • Replies 640
Posted Images
Heres the CAMS guide for mounting cameras.
Right click save target as
http://www.renew.asn.au/download/CAMS%20Ca...%20Mounting.pdf
Cheers for that, is it OK to mount it at the child restraint mount once the capsule is made up?
So how did you find it on the track??? Easy to drive around the response you miss on the street?
the car likes the track alot better, more room to rev!
on the track your able to keep it at 4000rpm and constantly have boost, the only thing that let it down was my driving.. lol cant wait to get out there again
oil temps hit 120
Who from here actually emptied their extinguishers on the RX7? I know Ando did. Who else?
Yeah Adam i did.
Ando my friend, you did a great job out there to get that 1:58 mate, i accept defeat. The thing i like about dueling with you is we drive each other faster, when you caught me i thought i was going pretty quick but then i think once i saw you behind me i picked it up a notch.
Hopefully next yr I'll be chasing you guys... if everything goes according to plan that is.
Ahh but I wont be standing still waiting for you. I've got a new mod going in this Saturday. :( Look out John. My mechanical diff will shave 10 seconds off my lap time at least!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
