ahhh yes.. how things move on .. from those coy tickles in the stock room from some strange deviant who kept on asking me to pickup stock on the floor, to the coming of age I feel now. I did always wonder why there seemed to be a flash going off at that very moment I was at full extension.
god.. that almost is me.. actually scarily adam has more meat on him :wub:
happy birthday mate, ill bring a couple of beers over when i grab that clutch, any preferences?
cooool.. anything other than tooheys is good for me. It'll have to be sunday, probably after midday, as earlier i believe i may be well predisposed with saying hello to the toilet bowl.
lies! I've been to skinnynerds.com - I was mr January 05 if i recall correctly! .. and I never submitted my own photo.. No sir eee.
Ahhh.. and then mark moved in to prey in his footsteps.. only to be later on heartbroken and had to move back to melbourne, when I constantly refused his subtle tapping at my bedroom door.
funny I was speaking to Dean just yesterday and he said that apparently there wasn't too much refusing of the tapping at all! In fact there was tapping all night long and there were no doors involved :wub:
funny I was speaking to Dean just yesterday and he said that apparently there wasn't too much refusing of the tapping at all! In fact there was tapping all night long and there were no doors involved :)
LMFAO, you guys are feral. Keep your fantasies to yourselves :)
Anyways bit late but Happy Birthday Gordo! Best of luck with the mid-life crisis :)
    • Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
