Thats not exactly true Paul. In the wet I actually think they are better than standard street tyres - as long as there is a fair bit if tread left. And thats the hard part because with normal street driving you'll probably only get 5,000km's before they are shot.
But for exmple I remember last year at Calder (track - not drag) a WRX being 3s faster in the rain on RE55's than on his "good" street tyres. Same deal as when R comps are cold - they aren't as grippy as when they are hot but they are still more grippy than normal tyres.
As said - the biggest problem with R comps and street driving is value for money given the short life span.
Agree 100% on the above....last year at EC during the motorsport trip it absolutely pissed down with rivers across the track and standing water everywhere. I was simply staggered at the amount of grip the RE's gave me even when cold. Gadg was using RE's then tried his street tyres and had nowhere near the grip that he had with the semi's.
Biggest issue with them on the road is definitely the noise and the wear.
  • Replies 62
Just to add a little bit of comparison to this subject.
At EC last year in the wet my car (worn RE55's) was quicker than Gareth's (worn fat streets) when it was slightly damp or drizzling. But once it started to bucket down I simply couldn't keep up no matter how hard I tried. And believe me I tried (Got in trouble for drifting too) Was only a couple of seconds in it. But I think the degree of water makes a difference.
Steve give 'Gordon Leven Tyres' a call (they are at Emu Plains 5mins from Penrith) I was out there yesterday looking, from memory 245/40/17's were $390ish and 265/35/18's were $490ish (go up to 315/18's for 11inch rim) and the slicks were 250/17 at $490ish.
They also get used R's from all the NSW events from $80ish which will give you a couple of events worth of usage.
245/18 $465
Just by calling a few places around I got a couple quotes for 245/40/18 in the $410 to $415 range. So $465 souds a fair bit more than one needs to pay.
ps. Competition Tyres in Oakleigh quoted $410.
Edited by DavidM
245/18 $465
Where was the $465 quote from?
Prices for Re55's have increased significantly recently so the places that are quoting 'old' prices most likely have stock they bought at the old prices and probably want to move them.
Nothing wrong with that though :)
Wish I had a rubber factory............I can buy a car with wheels at those prices. :P
I agree don't run them on the road................dangerous when cold and wet.
Buy a set with rims for the track...................that is all
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
