I'll just say first that I'm used to driving a corolla around, launching at traffic lights, cruising over speed bumps at 40kph, and taking any corner hard. So I'm basing what a nice ride feels like on that.
Maybe I'm just not used to stiff suspension, but my R33 just isn't "comfortable" to drive around in. I can feel every bump in the road, and most traffic lights I can't launch from because off the uneven-ness in the intersection. Not to mention the suspension is squeaky. Panels inside the car rattle a fair bit over small bumps.
Edit: Also should have mentioned that I can't hold traction in 1st after about 5000 rpm. If I have a heavy passenger or more, yes, but not just by myself. My tyres are SAVA INTENSA 235/45ZR17 94W, there's some other stuff on there as well not sure if it's important, "Tread 180 Traction A Temperature A"
My dad just bought a new Golf GTI, and to me the suspension feels incredible. It's stiff but at the same time very comfortable ie. I don't mind the stiffness. Which got me to thinking maybe mine isn't up to scratch.
Recommendations? Should I take it to an expert and get it checked out? I'm a bit wary of taking it somewhere and being told I need to replace things regardless of whether they need replacing. I'm a noob and I'm sure people will pick up on that!
Anyone near the sutherland shire feel like taking me for a drive around the block in a skyline with a good setup so I know what I'm missing out on?
Thanks!
Edited by bombastic
You might find that the suspension is shot. My R33 was like that till I put new shocks in it[ well second hand Bilsteins, which are better after a rebuild] Bet you find it crappy going down the Kingsway from Caringbah to Cronulla. Mine still makes a bit of noise down there.
Your suspension is probably worn out. When I had a R33 S1 i found a set of new standard suspension going cheap and put it on. Even though it was the same spec suspension it was basically a totally new car to drive. The old junk was just worn out.
Your tyres probably arent doing you many favors as far as traction goes either.
I had my mechanic come for a drive with me and he seems to think it's OK, and that "you get what you pay for" in a cheap car like this. But suspension shouldn't be squeaky like this should it...?
Please someone take me for a ride in something with a good setup so I know what I am or am not missing out on!
Edited by bombastic
Hello Bombbastic. From what you have said it sounds very much like you require new suspension.
Your wheels are having trouble leaving the ground over 5 rpm tells me that the shows are just not working well enough to hold the tyres to the floor on takeoff witch is common in worked car's.
I have 370 kwts at the wheels and still have no problem with traction unless I want to :)
So it sounds very much like you should have read the section on suspension and how it all works.
Was very enlightening and I believed that replacing it will more then likely take care of the power problem.
As for the squeakiness. That could have something to do with the suspension also but why don’t you just walk around the car and check your rubbers on all door and look for movement wear in the panels at the join's around the stress points of the car.
I hope this helps a bit. But please consult a reasonable mechanic before taking anything that anyone says as the word of god.
I have 370 kwts at the wheels and still have no problem with traction unless I want to :thumbsup:
Your suspension doesnt sound worn out to me, just very hard. Was ita Jap inport? I dont know much about Oz Skylines, do you import them a lot or were they sold in Australia from new? We have to import them in the UK and it seems the Jap guys really like their rock hard suspension set ups.
Rose joints can squeek as they lose lubrication, its possible your car has been fitted with adjustable camber arms etc to compliment the suspension and the joints are dry :)
Can you get a pic of the dampers?
Basically I find skylines with stock suspension in reasonable condition very comfortable to drive with not bad handling characteristics, and they should not squeek.
So something is not right, either it has rock hard jap spec shocks and springs or they are just rooted shocks. Squeeking is prolly from the suspension bushes, might be a good idea to replace the major ones especially if they are the standard crappy silicone filled ones. As for the rattling that just sounds like a car that has seen a pretty hard life.
Take it to a suspension shop and ask them to take a look. If you have the pedders $14 28? point suspension safety check get that done, you don't have much to loose and that may tell you something, just don't get any work done there, or at least don't book it in as soon as you get the report done - that is what they want you to do.
Rose joints can squeek as they lose lubrication, its possible your car has been fitted with adjustable camber arms etc to compliment the suspension and the joints are dry :whistling:
You are right the can squeek but he is losing tracking becouse of it. Witch indercates warn shocks.
I disagree with your assessment on the shocks.
If he had standard but worn dampers then he wouldnt have the hard ride unless they were combined with stiffer springs. A lot of the Jap imports we get run very hard coilovers which is why I suggested that as an issue :whistling:
Edited by bren
yup im in the shire also!!
hmm well i got nissan shocks with lowered springs atm..
Ride is excellent and handling is also good. You wont even feel a bump..
Awesome, I'll shoot you a PM as soon as I ditch the flu :O Sorry for the late reply, something seems to be up with my thread subscription.
Is it possible that the tyres just suck?
I have 370 kwts at the wheels and still have no problem with traction unless I want to :(
If you're referring to the shockabsorber 101 thread, can't say there was much to learn there other than that some shocks are better than others. Otherwise please enlighten me :wave:
My mechanic is very well respected, and seems to think it's OK, and "thats what you get". But this doesn't make it any more enjoyable to drive!
Yeah imported, but from what the first aussie owner said to me, it had the suspension changed when it came into the country.
Rose joints can squeek as they lose lubrication, its possible your car has been fitted with adjustable camber arms etc to compliment the suspension and the joints are dry :O
I'll try. Mechanic did mention there is nothing to lubricate.
Or maybe the car has had suspension that's too hard :D
There is one nearby, sheesh for $14 might as well.
Thanks all for your help! I'll consider what to do next after (if) I've been in siddr20's ride.
I think that your tyres could also be contributing to the harsh ride, as I also have Sava Intensa tyres and mine are only 16", and if you examinie the tyre compound, they feel more like rocks than rubber. I am getting new tryes this weekend to Toyo TR1's and I believe will add some difference in ride comfort.
Just a word of caution for eveyone: Sava Tyres Grip in the Wet = 0 (have gone ice-skating more than once in the rain)
Edited by godspd
Can your sava's hold traction in first, and if so do you also have an RB25DET? If so then that would indicate my suspension is the cause of loss of traction.
lol,
No,
5000rpm in 1st,
what is traction?
lol
Why not find out if u have an after market suspension or not?
look at it, most of the time, u can tell them stock apart from aftermarket.
or snap a pic and post it on!
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
