hey
im considering making a twin turbo setup for my rb25det
consisting of a pair of custom manifolds, 3 runners each
2 t3/t4 turbo's, internal gated
and then the piping to merge just before the intake for the cooler
i know people myt say stay single, but ive been through all different setups, low mount and high mounts, but jus trying something new
thanks 4 ur help
Is there a question here?
Are you after some sort of information?
Thoughts?
As there isnt a question, i can just give free thought...
I assume the motor is still internally stock.
Using TWO t3/4 butcher turbos as i like to call them is going to result in response probably equal to a T88. You are not going to see boost before 5000rpm, could be upto 5500rpm. Or more.
Most "butchers" make around 220-250rwkw... so effectively putting two of them on there is going to be a very fruitless excercise.
Many T3/4's have little thought behind them, and are also bush bearing which certainly is not going to aint you in your endeavours.
Trying something new is good, but gotta wonder why no-one else has really done it (commonly) before, its 2006 and skylines have been around for a long time now.
I assure you plenty have thought about it and realised cost and the performance isnt worthwhile just for being "different" :D
why need a massive budget.. ? sure you could go for the 2510's or gt-ss's but if you wanted to do it cheaper you could just get a pair of N1 gtr turbos, or garrett's equivalent..
fact is, toyota have done it and it worked well, i've seen a few 1jz's running bigger twins and making good power. I've driven a jza70 supra with HKS t3g's (early 2530's with smaller turbine housings and 360 thrust bearings) its a response machine and makes over 300kws.
Plus with the ports lining up on both heads, modifying the flanges on a pair of cheap gtr manifolds would cut costs even more, and the piping would be even easier!
to me it sounds like a kick ass idea, i'm surprised more people havent done it.
go for it dude!
Karlos
Edited by kwazza11
Why not put the Rb26 head on the 25 block and use the setup as if it were a GTR. You might want to bore the block out 87mm to get a little more capacity under your belt, do some major port work including larger valves and you could get that thing spooling fairly quickly on a couple of GT2530's.
But then you end up with something that looks like a RB26, but... just isn't.
The RB25DETT has been done here in Vic, however it's not running anymore.
I'm slowly gearing up to do this. I like different
Hey,
I'm actually about to try this myself, just sourcing cheap bits at the moment. My philosophy behind it, as i'm not after exactly "massive" power at this stage is to source a cheap pair of GTR turbo's and possiblie manifolds (depending on how hard it turns out to be modifying the flange on them) and doing the same mod. I trawled through a few japanese sites and found these on one:
although I think modifying the original ones (read: just not bolting up cylinders #1 and #5, haha not really :D) might turn out cheaper and easier than getting something fabricated like this.. Anyway the whole appeal behind the idea to me is a decent setup using cheap, quality second hand parts that are really tried and proven on an entierly new setup..
mark
Edited by aphid
2nd hand ceramic exhaust wheel on the stock turbo's sounds like a ticking time bomb to me. you really should change them to steel wheel's. one member has seen this failure destory an rb25dett before
The turbo's would be rebuilt at some stage, although the actual condition they were in when I recieved them would decide on how long that would be... I wouldn't be pushing them beyond what the acceptable limits are on the rb26 with the ceramic exhaust wheels at any rate :D
EDIT: Check out http://www.calaisturbo.com.au/printthread.php?t=13913
Edited by aphid
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
