Thats too cheap. It wont be changing everything thats required.
Parts/oil alone your looking @ around the $400-$600 mark depending on what brands you use.
Have a read here mate, posts by deorbit are very informative of what requires doing at the 100k service.
http://www.skylinesaustralia.com/forums/in...showtopic=49722
Perfect thread for you, might save yourself some money aswell as some of it is very much DIY and its a large task
cheers -ash
cheers -ash
yeah, i read it, i was thinkin the same, it is abit too cheap, and i know what can happen if its not done right, i've decided to go with another quote, alot higher than 400, but more realistic for the work and not overly high...
No worries dude, 100k service is very important, especially the idler bearings. They are the single most important part along with the timing belt.
Print the thread off if you want... and have the mechanic cross off each thing the do/dont on the list for you. Or use it for them to quote on :nyaanyaa:
Just as a guide for them aswell
dont scimp out make sure ya do the water pump at the same time while you have it apart . in in the middle of doing mine atm timing belt /tensioner and idler bearings/water pump/new fan belts all round may as well replace it all and know ya wont have probs for a long time
this is what i'm thinking, and i have come to learn that you get what u pay for...
Just read this; I happened to be at EAS (Vic was tunning my car) when he received this call.
I have used them for the past 5-6years and have been more than happy with their quality of work and prices. Don't be fooled, higher prices do NOT mean better quality. If you where to personally visit the w/shop, there is a reason why they are always filled with cars, so i am not the only one that appreciates their standard of work. My car is a great example of a neat and safely modified Skyline. In my 4.5years on SAU various shops had become "the flavour of the month", most of these have come and gone.
Did you discuss exactly what you wanted done, which parts you wanted replaced. May pay to give EAS another call and speak to Vic directly. Admittantly he may take a little longer than others, due to his constant work load, but you can rest assured, that the car will be completed to the highest standard.
And yes Ash parts are always genuine, without the over inflated mark-ups that other w/shops may charge.
Should you want to discuss this further, i am more than happy to.
It's worth about $600 alone in parts at trade, not bagging ANYONE buy how it is possible to do it for $400 inc labour? Impossible. I think you will find they may only do SOME parts of the service eg. Cam belt and bearings.
Simple to solve - Ring them and ask for specific details on what the service includes. Easy :D
yup, i had my idler bearings changed. The mechanic showed me my old ones. It surprised me how roughly they turned when turned by hand, they must have been on the way out...
That is true.
That is why i told him to confirm what he wants done. I still have my original bearing, that where checked and were fine. It is always good to discuss such issues in detail, not just "how much for 100k service", Vic:"$400", "thanks, bye". Which is pretty much how it went down, as Vic was too busy to take the call. Best to get a break-down of parts cost and labour cost.
PS: My bearing were still very smooth and rotated nicely. Maybe they had been replaced in Japan, maybe my km where genuine at the time (69k), i don't know :
If your doing a 100k service @ $450 your running at a massive loss.
No business does that. So its one of the following.
1) Risky parts.
2) Not everything that should be done, being done.
There are no two ways about it. Oils alone would come close to the $100 mark. Diff, g/box and motor.
Then timing belt, water pump, idler bearings, other drive belts there is another $250
Then add in plugs, oil filer, fuel filter, brake oil change/bleed, air filter etc $50
Compression Test, Radiator flush $100
We are @ $500 before labour even comes into it. If a workshop can do all of that in an hour i'll be very much surprised. So you could safely add on 3 hours labour for that for even the fastest workers.
It a simple case of things are not gonna be done as they should/require for $400.
Why quote $400 if your gonna end up...
1) calling the customer back to up the ante on the price to $700-$800
2) not do the job correctly
Doesnt make sense to me.
That is true.
Yup spot on, detail is a must :D
As usual Ash, jumping to pointless conclusions before reading the posts properly.
All those things you mentioned do NOT have to be done at 100K, why not spread the cost and so some b4, some at 100 and others after? I have stated numerous times that details have to be discussed and sorted b4 the job. Not all customers can lay $#### on the table at one hit, so he will not replace all the parts at once. But if a customer specifies what they want, and this gets done way b4 Vic receives the car, then a proper quote will be given.
All I stated was that the parts ARE genuine, and you still have to add your bullshit that they are dodgy, just because we are not talking about your "buddy" w/shops.
How many w/shops have you blown your horn for?, only to end up moving to another w/shop because the previous didn't live up to the reputation. I know of two that have quietly been removed from your vocabulary, over the last few years.
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
