OK this post is directed at s15 owners, I have just put a few mods on my s15 including a boost controller and when I wind the boost up and give the car a squirt it sounds like the engine cuts in and out, I have been told this is the fuel cut defence system in the standard ecu which momentarily shuts the fuel system down when you try run more then standard boost that the ecu is set to. If this has happened to you in your s15 plz tell me how you solved this problem thanks
https://www.sau.com.au/forums/topic/125930-need-help-fuel-cut-in-my-s15/
yeh its that, do a search......
also if you look at nissansilvia.com they will be a lot more specific to your car. i mean were all a friendly bunch here lol, jus if you get a problem thats really specific to the sr20 or s15 they will be able to help you out bucket loads.
I have an s15. Fuel cut from boost is not an issue on s15 with the boost levels you should be running.
On the dyno mine saw 18psi with stock ecu very briefly and there was no boost cut.
With standard ecu I would not run any more than 11psi as the ecu in s15 makes the midrange REALLY lean. Do you have a boost guage to determine what boost you have set? Once you have power fc I wouldn't run more than 17psi. I only run 16.
If you can, don't do any boost tuning yourself if your new to this its a really bad idea. Do it on the dyno. A rebuild will cost you more than $4k to do it properly.
The problem you currently have will either be massive boost ie. >20psi or more than likely the spark blowing out. Gap the plugs correctly. If you don't know what to set them to take the car to a workshop.
He is right though.
Whilst its a Nissan, i couldnt tell you the first thing about an SR, what problems are common to them or anything.
Obviously the basic things like AFM/plugs/coils... but apart from that i couldnt even tell you if the coils are a usual suspect on the SR like they are on the RB...
i think it may be a coil issue. i degreased my motor last night, and despite my best efforts 1 of my coils got rather wet (the rag i had covering it got caught on the hose and pulled it out of the road a little bit). anyway after i finished i took the car for a drive. once it had warmed up i got into it a bit and at about 3500rpm (once boost had come on fully) it was dropping a cylinder due to it shorting out. it just sounded like the speed limiter, but it would keep reving. i kept driving normally for a while and it went away once the coil fully dried out, and wasn't there when i drove today.
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
