OK this post is directed at s15 owners, I have just put a few mods on my s15 including a boost controller and when I wind the boost up and give the car a squirt it sounds like the engine cuts in and out, I have been told this is the fuel cut defence system in the standard ecu which momentarily shuts the fuel system down when you try run more then standard boost that the ecu is set to. If this has happened to you in your s15 plz tell me how you solved this problem thanks
https://www.sau.com.au/forums/topic/125930-need-help-fuel-cut-in-my-s15/
yeh its that, do a search......
also if you look at nissansilvia.com they will be a lot more specific to your car. i mean were all a friendly bunch here lol, jus if you get a problem thats really specific to the sr20 or s15 they will be able to help you out bucket loads.
I have an s15. Fuel cut from boost is not an issue on s15 with the boost levels you should be running.
On the dyno mine saw 18psi with stock ecu very briefly and there was no boost cut.
With standard ecu I would not run any more than 11psi as the ecu in s15 makes the midrange REALLY lean. Do you have a boost guage to determine what boost you have set? Once you have power fc I wouldn't run more than 17psi. I only run 16.
If you can, don't do any boost tuning yourself if your new to this its a really bad idea. Do it on the dyno. A rebuild will cost you more than $4k to do it properly.
The problem you currently have will either be massive boost ie. >20psi or more than likely the spark blowing out. Gap the plugs correctly. If you don't know what to set them to take the car to a workshop.
He is right though.
Whilst its a Nissan, i couldnt tell you the first thing about an SR, what problems are common to them or anything.
Obviously the basic things like AFM/plugs/coils... but apart from that i couldnt even tell you if the coils are a usual suspect on the SR like they are on the RB...
i think it may be a coil issue. i degreased my motor last night, and despite my best efforts 1 of my coils got rather wet (the rag i had covering it got caught on the hose and pulled it out of the road a little bit). anyway after i finished i took the car for a drive. once it had warmed up i got into it a bit and at about 3500rpm (once boost had come on fully) it was dropping a cylinder due to it shorting out. it just sounded like the speed limiter, but it would keep reving. i kept driving normally for a while and it went away once the coil fully dried out, and wasn't there when i drove today.
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
