Hey Fellow Skyliners
My Brembo's are in need to be painted and I was wondering what is the best method.
1. Painting them myself, using VHT brake paint.
2. Sending them away to be painted professionally. Recommendations who?
Also, Would anyone know where to find the "BREMBO" stickers?
Thankyou in advanced
Intune
https://www.sau.com.au/forums/topic/126022-painting-r33-brembos/
Give then a good clean, mask the area off with newspaper and way you go. I think with brembos it should be stamped on the caliper just scrap of the paint with a knife. Use a paint pen to high light BREMBO.
Don't waste money on VHT. Looks crap after a few heat cycles on the track on my racecar, although that was a nice job on those above.
Go with the Duplicolor Metalcast. Looks too sweet. I've used it on the cam and front cover of the RB26 and the Sumitotmo calipers on one of my GTSt's and it is wonderful.
Thankyou for your replies.
JK
Your mate Brendan has done an AWESOME job and look great. Still I am unsure sure how he done the lettering "BREMBO".
Would be OK if I email him?
Cheers
intune
GTRgeoff
Would I find that paint at repco or somewhere like that?
Cheers
intune
No need to be formal here. Geoff is just fine :)
I get mine from Supercheap. Used a wire wheel on the brakes after a full brakekleen, then masked and used the silver base coat, then the crystal red top coat for a similar finish to this
Geoff
Looks fabo, did you use a clear coat?
No, the crystal red is a semi clear over silver base. I have some 2 pack top clear and that would be great but might not like the heat.
The metalcast is heat resistant and brake dust doesn't stick so stay crystal red.
You can get purple and some other hideous colour but the red is good for me.
Thankyou for your help.
will try this weekend.
I repainted my a while ago exactly the same. The stencil I had made by a sign shop. I can send you the Brembo artwork and then simply give them the file and tell them that you are wanting a stencil for painting. I did find a stencil kit you can buy, however that was out of the UK. Painted mine using VHT black with silver "Brembo". Went over it all with a high temp clear coat however the clear coat perishes every time I go on the track so I simply wiped it all off. VCHT has been great ever since.
you need the stencils to do the calipers..... i have it if anyone needs....also 2 pack clear is more than strong enough for the application....i dont know why you guys think that single pack paint would be more durable than 2 pack
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
