I just had discussion's with my mechanic where i told him i wanted a 10w 40 redline rating in the gtr! What it had!
I find out he couldnt get it and has put in a 15 w 50 version ... NOw i am paranoid about this because of the complex componnents in the 26's head
. He made a statement that i will have better oil pressure because it reads low on the guage ...
I just belive the Gauge is intermitent . and waiting to install a better device..
Now we are talking $130 worth of oil here and i just wanted opinions if i should re change or run it until next change ... What could happen ? Topend ware?
to me the motor is very Quiet and strong with 140,000 km's .. I do know it had its magor service at 100000 belt (Etc)
What do you think ?
https://www.sau.com.au/forums/topic/126182-wrong-expensive-oil-put-in-redline/
Bascisally, nissan recommend a 7.5 w 30.
Thinner cold viscosity helps it to lubricate the engine quicker when it's been sitting e.g. overnight. Most of the wear to an engine occurs during start up.
The warm viscosity isn't as important. But a thicker oil requires more heat to break it down at high temperatures.
Yeah its pissed me off a bit ..... I will do a short change 2000
To be hounest i just want the car outta his shop ...
He came across as knowing a bit but as you go along you realise that he is learning as he is going ... This is the last mechanic to ever touch this Car in the town of Albury Wodonga .. I have learnt so so the hard way ....
it is mega Cold here in winter so it makes no sense again!
Thanks
Ish!
Yes do your own oil changees and use a nice PureOne or genuine filter.
The 15w50 will be fine, do remember nissan recommend 7.5w30 for a new motor with jap conditions being considerably cooler than ours.
I'd leave it in for the whole 5000k. No need to drop it. :(
As your spending so much on oil consider have an oil analysis done on it after 5k, then drop in the 10w40 do 5k on it and give that an oil analysis too. Will indicate which is better suited to the driving and condition of your motor.
Can you even get 20W50 in a good synthetic oil?
I've only seen 20W50 in cheap minerals oil, good for old XF Falcons and the like.
Have a go yourself, you couldnt, f**k up more then your mechanic already has. Didn't even do as you asked.
it was a case of me swallowing my temper to get my car outta there!
Redline make it in that Viscos For there Big ol Gappy motors in the States .
No, don't dump the oil. Redline being polyol ester base have pretty good cold pour point, i would say used it to 10k before you dump it.
The oil you have will be fine, but if you want to have an argument with the mechanic that's up to you. One-off oil analysis falls into the same category as cryogenic treatment......a complete waste of time and money.
Not a complete waste of time.
Early notification of fuel, water air filter problems... And gives you an indication of the oils VI over your change period.
With regards to wear yes it can be a waste of time.
SteveL it was way more things than just the wrong oil that caused tension.
I simply found out he had BS'd me on a few points > this Was not the Point of the Thread
I Asked here about the viscos because i didnt know and wanted to get the info form people that did, incase of Damage.
Regarding the OIL analysis I just found it Personaly interesting to see what becomes of the oil after a term, not to argue.
Its all good now ... Cars home ,it has its proper oil and the Vl Commie has its own batch now too, Nothing Wasted!
thanks everyone.
Edited by ishh
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
