  • Replies 46
Originally posted by ONARUN
i guess you're right.
damn, i wanted to argue
I'll Argue,,,,$90.00 bucks for some Oil thats only in there for 5000kays,,,,Jimbo you starting to sound like a sheep. BAAAAA...BAAAAA
Birty,,,,I have no idea if the Nismo key will fit a R32,,,shit I hope so,,,its better money spent than on "Magic" oil. E-mail Just Jap,,,,they will know.
Neil
https://www.sau.com.au/forums/topic/1262-nismo-keys/#findComment-25502
No Jimbo,,,,no Kiwi in me buddy,,,,lottsa French though....
I would have thought the Nismo key would be of great wank factor for you poor Aussies....
Last time I check the rice chart You were right up there buddy,,,then again we ended up with 2 GTR keys,,,,,Does that mean we have 34 more Kw's.
Still waiting to see your beast,,,,I'm starting to think you own a Commodore.
Neil.
https://www.sau.com.au/forums/topic/1262-nismo-keys/#findComment-25529
It was more of an insinuation of Kiwi being in a sheep, but that's another story :eek:
.... as for my baby, you'll hear her her coming well before you see her, don't you worry ;) I just don't feel like making an ass of myself (moreso) by driving uninsured. All will be revealed in due time.
Make no mistake, if you choose to test my resolve in this matter, you'll be looking at an outcome that will have a finality which is beyond your comprehension, and you'll not be counting the days or the months or the years, but millenniums in the house with no doors. :)
https://www.sau.com.au/forums/topic/1262-nismo-keys/#findComment-26059
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
