Alright I have an s13 which I am currently swapping an r33 rb26 into and I will be running the rb25 tranny. I am asking if I should use an r32 gtr clutch since the r33 clutch is pull type and the r32 would be push type. Basically which clutch do I need r32, r33 Rb26, or rb25 clutch. Any info on which one to use would be great. thanks guys.
https://www.sau.com.au/forums/topic/126380-which-clutch/
You can get any clutch you want. You can get converters for push to pull type so as long as you get that it should work. I'm assuming you would need a clutch though that works with your tranny though.
Edited by jantolis
https://www.sau.com.au/forums/topic/126380-which-clutch/#findComment-2333445
cool.
i honestly sware bu the os-giken twin plats.
there cheap as and last ages. easy to drive.
ive had a ts2bd. (480hp) in my (gtr 315awkw) for about a year. its copped everything i thow at it. track days/drags/general tool driving :D
and for 500bucks of ebay (second hand) its the best value for money yet. :wave:
on another note. i had a nismo gmax. spec 2 in my dr30 (r34 5spd/rb26) it wore out REALLY QUICK).
you can try a good single. but for the same money i know what id raher :O
ps.. 33 5spd gtst is push clutch.
an you can get PULL to PUSH converters not push to pull
https://www.sau.com.au/forums/topic/126380-which-clutch/#findComment-2348196
Alright so i will be getting an r33 rb26 with a pull type clutch on it. And I will be using the push type rb25 tranny. Is there any way to convert the clutch that will come on the motor to work with the tranny. I basically am looking for the cheapest solution possible right now. In the future I plan to run an OS Giken, Nismo, or Exedy but for now I need a cheap solution. So what is a simple solution preferably a way to use the clutch I have now with the rb25 tranny aka a way to convert the pull clutch to a push. Thanks guys.
https://www.sau.com.au/forums/topic/126380-which-clutch/#findComment-2375542
dude thats a killer conversion!!!! ive got tha same set up... except r32 rb26 and r33 gtst g/box..
i recomend going for the best clutch you can afford, i have a os giken twin in mine and it hasnt
been able to hold the power!!!!! mine is pumping out 403rwkw @24lb... if your motor is standard
i guess a twin would do......... stuff going a single.. waste of time.. I think singles are for 4 cylinders!!!
https://www.sau.com.au/forums/topic/126380-which-clutch/#findComment-2377752
Simple answer to a good clutch.
Call Jim (sticky thread in this section)
I have a OS twin with my RB25 box, and that'll be going onto the RB26. Wont be an issue.
The OS did take an exceptional beating, and when we pulled it apart, even though the OS plates are the "thickest" in terms of clutches. It was just about rooted but still worked like new.
That said, and using/seeing other guys with a Jim Berry special... i would choose his should i require another clutch at any stage
https://www.sau.com.au/forums/topic/126380-which-clutch/#findComment-2378674
no there isnt a way to convert push to pull gearbox. i think..
you are governd by the clutch arangment for the gearbox. not the engine.
https://www.sau.com.au/forums/topic/126380-which-clutch/#findComment-2385025
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
