Hey ppls.
For a little while now, I have been populating an XL Spreadsheet of Dyno Figures to compare my tunes and modifications.
I got the idea off Cubes, so I can't take credit for the idea itself.
BUT.
I'm going to open up my little spreadsheet to everyone to play with and add their numbers too.
Maybe we could even prepare a HUGE one to compate all sorts of fun and wonderful things.
Anywhoo.
Attached is my spreadsheet with graphing, and you could perhaps add to it, or cut and paste it, or add your own numbers too and have play.
BASS OUT
Power_Curve_XL_Sheet.zip
https://www.sau.com.au/forums/topic/126563-power-figures-dyno-chart/
  • Replies 101
top work bass but i think it should be plotted into mysql with a php site so it can be customised and comparison at the click of a button. that excel sheet will suck when 5 other people add their results. like the v8 one you found, that was tops. we need that
I have done a remake of the sheet. It will require the re-entering of the figures unfortunately, but I have made a couple of changes.
I have changed the speed scale from 3's to 2's.
More notably, I have set up the graph to display only 5 figures at a time. I have added a Rank function (row 2) so you just enter in the numbers 1 to 5 above the figures you want the graph to display, then press the "Sort by Rank" button. The figures will be sorted and the graph will display the results you wanted.
Or you can sort by Max power, I have added a Max Power row at the bottom of the table, you can sort to show the 5 most powerful cars on the graph.
Hopefully this will be a little more user-friendly and a bit easier to read. I can always change the graph to read more than 5 if need be, but having the graph limited to a specific number of records, rather than all of them being shown at once will keep things a bit tidier.
I hope this helps.
Power_Comparison.zip
Needs to be RPM based not KPH
will be more accurate as kph, not rpm, as most people will only be guesstimating rpm. not many dyno sheets have rpm up the side to base it of, and if i go out on the road and say that i get 100kmh at 2850 rpm, that doesn't take into account both my speedo and tacho being out.
Edited by mad082
To save the hassle of re-entering all the figures, I made the changes to the original sheet.
The graph is now on a separate tab, and will display only the first 5 records. Enter the number 1 to 5 of the records you want to see, and press Sort by Rank to have those 5 appear on the graph. I added a Max power field, and a sort macro to sort by max power so show the top 5 most powerful cars.
Added RPM to the graph instead of speed. I used the formula to work out the RPM for the speeds we were using, rather than reworking the speed for a given RPM because that would require re-entering all the power figures.
  • 3 months later...
just curious, on the graph 102km/h is lined up with 3643rpm...on my dyno graph the rpm's dont line up with the graph 102km/h=3849rpm
what can be possible answers to this...as far as i know ratios are stock ( i havent changed them) would it be my rims? 19s?
just makin sure ay
cheers...ben.
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
