Just had a thought,
GTR fenders, whatever bonnet. grill, bar and rims you wanted. Added cost of spraying and fitting = ~$7-8000. Maybe more, I'm no expert on costs.
Sell your GTSt + at least $8000 = GTR. Its win win, plus you get an RB26, 2 turbos, 4WD, 4WS, GTR seats and a GTR badge :(:P
  • Replies 99
Just had a thought,
One question champ.... Why? He's building a drag car - what you've suggested would make total and complete sense were it to be a road car but it isn't. GTR's are VERY heavy, harder and more expensive to make quick for drag racing and a waste of money for this application. Did I mention how heavy they are?
BezerkR32 already has the RB26 but it's not going on an RB26 block, doesn't wan't 4WD for the reasons stated above and 4WS? Not many corners on a drag strip :O
GTR badges are important though!
Adrian
little bit late know, guards werent as expensive as you think, and not really keen on two turbos, Gtr are the most fun on the street but its not really what i need for the track. besides, just stuck this in. also trying to keep car around 2500 pounds (1130kg) big ask in a gtr or 33 whale.
Just had a thought,
Edited by BezerkR32
Just had a thought,
Sell your GTSt + at least $8000 = GTR. Its win win, plus you get an RB26, 2 turbos, 4WD, 4WS, GTR seats and a GTR badge :(:O
Not everyone wants an overweight 1500+kg car, or a small 2.6lt motor :P
I'm the f**king juggernaut, bitch! :(
As djr says, why not buy aftermarket cosmetics? Carbon fibre is lighter and stronger than aluminium ya know.
Hey 28" rims, nice :P
I find aftermarket cosmetics do not offer the quality factory parts do, alos there is hardly a wide range of parts for r32s. Unless you want the some cheap fiberglass kit with a poor finish.
Also carbon fiber is dick all lighter and harldy legal anyways.
It's nicer to have Jedi powers.
Bye bye, Michael.
r u jedi or sith?
jedi use their powers for Good purposes, not evil ! :sorcerer:
Bezerkr,
go the GTR guards - get the rear end pumped out. fit big grippy tyres, run 9s
have fun doing so too.
btw: Dont test out that roll cage, ok? Might look silly on a 400m straight strecth of road, lol !
Sounds good, can you get me one for under $400?
How about the front bar from the gts4? I dont know if they all have one, mine does and it has a large front opening, looks good, is factory and not a gtr...
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
