Just found out something curious
Officially, stageas have less power at the flywheel stock than R33's.
Skyline http://english.auto.vl.ru/catalog/nissan/s...e/1996_1/21671/
vs
Stagea http://english.auto.vl.ru/catalog/nissan/s...a/1997_8/21850/
Why the hell did they detune the stagea when its 300kg heavier!
https://www.sau.com.au/forums/topic/126625-stagea-vs-skyline-std-power-figures/
Nissan decided that the S1 auto gearbox needed some protection from the heavier weight
The manual (S2) Stageas have the same power as (R34GTT) Skylines
But what about S2 autos and R34GTT autos?
:D cheers :D
Edited by Sydneykid
Somewhere in Skylines there is a comparison of a Stagea, (S1 or S2 I dont know) and two or three other FI cars. The Stagea did better than some. Perhaps someone (SK) knows what thread.
According to this: http://english.auto.vl.ru/catalog/nissan/s...a/2000_6/21829/
The S2 Auto and Manual both have 280ps, which doesn't surprise me too much.
I was under the impression Stagea rb25det runs a little less boost that R33 versions. Like 6-7psi Stagea, 8psi Skyline. Although that would imply different ECU maps, otherwise, based on Stagea AF's, the Skyline would be too rich.
It's just a different calibration to protect the auto. The autos break! Heaps of cars are detuned for the auto variants. The Stagea is detuned a bit more than the skyline auto because it id heavier and AWD.
yea true the detune it cos their auto gearbox cant take it. This is also true for an Rx8 an uto the rev limit is at 7k where the manuak goes to 9.5k rpm.
well, i really dont think 10kw difference will kill an auto box....
but hey, we've all worked out an extra 60-70kw can :cheers:
More likely the 20 nm of extra torque
Regarding boost, our Stagea came with 4 psi / 6psi (high / low)
The R33GTST came to us with 5.5 psi / 7.5 psi (high / low)
So my guess is the extra 1.5 psi of boost accounts for the torque difference.
Auto ECU’s and manual ECUs in R33GTST’s are definitely different.
When I swap the turbo on the Stagea, I will check the wastegate actuator spring pressure. If my guess is correct, the Stagea wastegate spring should be ~1.5 psi lower than the R33GTST spring.
:ban: cheers ;)
I always thought this was just down to slightly different configuration between the two cars.
To use another example, look at where the VQ35DE engine is used, its in like 5 different nissan cars (probably more), including the 350Z, stagea M35, maxima, skyline v35, patrol?, and there are sure to be others I've missed.
In all of these cars the power figures differ - either in kw or torque or both.
I figured it was just that the setup is configured differently depending on the purpose or the target market of the car.
Sounds like the same theory diesel engine manufacturers have.
Most common rail deisels will produce a difference of up to 200 HP from the same motor simply by programming the ECU. You simply tell them what you want the motor to do and they'll program it for you.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
