  • 5 months later...
Hey
I ended up getting the castrol vmx80 for my gearbox but i never bought any diff oil, i'm about to get some of that redline 75W90 for the diff, the only thing i'm not sure about is do i go for the synthetic oil or the shockproof oil? on there site the 75w90 is listed under synthetic only, not shockproof.
If i do go for shockproof, should i get the superlight - lightweight or Heavy.
thanks
Edited by Hulk1010
https://www.sau.com.au/forums/topic/126666-diff-oil/#findComment-2806116
Redline 75W90 Gear Oil is supposedly good.
I use it in my diff it is very very good , always had problems around roundabouts and tight corners with the inner wheel locking up tried a few oils none were any good , redline fixed my problem
I thought shockproof isn`t an LSD oil only for the gearbox, i use the Blue shockproof in my gearbox its mad too
https://www.sau.com.au/forums/topic/126666-diff-oil/#findComment-2806488
LightWeight ShockProof™
A unique gear oil designed to lubricate racing transmissions and transaxles which see serious loads (not recommended for most syncro-type transmissions). It has excellent low-temperature flow which allows easier shifting when cold. May be used to obtain maximum power transfer in racing differentials which do not see high temperatures. Similar to a 75W140 gear oil, but with the lower internal friction of an SAE 30 motor oil.
Used in two-stroke and four-stroke motocross transmissions (often mixed in equal parts with SuperLight ShockProof™ Gear Oil).
Used in most road-racing differentials with moderate power and dogring racing transaxles.
Taken off the redline website , funny it not recommended for most synro gearboxes works mad in mine
https://www.sau.com.au/forums/topic/126666-diff-oil/#findComment-2807902
Yeah I'd make sure its suited to LSD diff's though..
You don't need "LSD" oil for a standard viscous diff. the viscous LSD unit is sealed from the rest of the diff enclosure and has its own fluid.
If you have a clutch type LSD (ie, you have a GTR, or your diff centre is aftermarket, or you have a skyline with A-LSD) then you need an "LSD" oil with friction modifiers in order for the clutch plates to work properly.
https://www.sau.com.au/forums/topic/126666-diff-oil/#findComment-2808155
I went to repco, autobahn and super cheat auto today and none of them had any redline products that i could see, where can i buy this stuff besides online?
--Nevermind just found some contact locations on there site--
Edited by Hulk1010
https://www.sau.com.au/forums/topic/126666-diff-oil/#findComment-2820264
instead of wasting your money on expensive redline which wont' do anything, because your diff is viscious (separate fluid for the viscous), I would honestly, use a castrol fluid.
Castrol lsx90. Cost ya about $30 for a 4L big bottle. You'll need 1.8L.
Castrol oils are a fairly good place to start from. At least it'll be correct.
Then, see how it feels, if it's good, then fine, it's good. From there, if you have a problem, then go mucking around with different fluids.
I have a mech diff, so I'm using motul oil, just so it changes the properties (won't do much to a viscous).
https://www.sau.com.au/forums/topic/126666-diff-oil/#findComment-2820448
So you only need LSD oil for a mechanical LSD? And viscous LSD has a sealed in amount of its own special fluid you dont ever need to change??
https://www.sau.com.au/forums/topic/126666-diff-oil/#findComment-2821002
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
