I didn't use a jun collar.
I took my r32 gtr crank to an engineering workshop and got them to machine the nose down and heat shrink a 4140 moly sleeve onto it.
They then machined it to r33 gtr specs.
They charged me $169 all up for everything but prices elsewhere could vary.
They can get most of the measurements they need from the r32 crank before they machine it down.
You just need to tell them how long to machine the flats.
If you go for a jun collar they still have to machine the crank and heat shrink it on.
got the collar with the pump...good price too...thanks CRD
so ill fit it...looks like the nose of the crank is machined and the collar is pressed on.
it comes with two grub screws so they will hold it in place.
I build my own engines.
thanks Nik (amaru)
I take it the grub screws are inserted 90deg from the drive faces (flats)?
The grub screws are just an extra precaution. You need to machine the crank to the right clearance (negative) for an interference fit.
Bob Lee at Action cranks has fitted squillions of them for a lot of engine builders.
when we do our we oil bath the collar also so its a little tighter on the tolerance (heat bath etc), but yeah as mentioned, machine the old drive off the crank, tolerance fit the new one, and drill grub screws on the flats of the drive ensuring they are bellow deck height, lock tite them in and your away.
Bingo, exactly what we did with our rb30det in the racecar. Except it was an rb30 crank obviously. Has worked with no dramas so far. I must say the drive section of the collar is massive in comparison to the std drive on the crank, well once again for rb30 crank lol. Bigger is better in these circumstances strangely enough.
It's a 2 thou interference fit. Then put the crank in the fridge and the collar in the oven and press it on. Temperatures normalise and it ain't going anywhere. Grub screws are just a precaution.
>_< cheers :wave:
Edited by Sydneykid
>_< cheers :wave:
some say to put the screws in on the flats...and others say 90deg from the flat face. Will a rebalance be needed??
We put them on the flats, I am not sure that it matters. They are also loctited in of course.
The diameter and weight of the flange is not really enough to put the crank out of balance.
That said, I always check the balance of RB cranks every time I disassemble an engine. It’s cheap insurance.
>_< cheers :wave:
:wave: cheers :wave:
Yeah...same...will balance after collar fitted
FOr the 30 mins it takes to check the balance we always do it!! I have never put the screws on the round side always on the flats, dont think it matters as mentioned there a precautionary measure.
We dont need a freezer in canberra just leave them outside in the morning in winter in canberra and bingo you have a crank thats -4 in temp!!!hahaha
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
