Quick question, how do we mix the gauges we want into the $175 bundle when ordering from the website?
The only way i can see to do it is select the items individually but that ups the price quite a bit past the $175 mark.
  • Replies 57
Hi mate, we have a number of preset options on the website as far as the bundle pack goes, but if you want to customize the pack, simply pm me and I will provide instructions for direct deposit payment.
Nice and simple.
Cheers,
Steve
  • 3 weeks later...
Hey Mate,
Would you do a special price if i buy the lot (5x)? thats boost, oil press, oil temp, water temp & air fuel ratio plus gauge holder delivered?
Cheers.
  • 3 weeks later...
Pm's replied, thanks all.
We have hundreds of gauges in stock ready to go.
Questions? Please dont hesitate to ask.
Cheers,
Steve
i'll ask him but it fits and it fits nice. wish my r33 has factory centre consoles like that. perfect fitment and looks the goods at night.
Hi, I'd also really like to see them if it's not too much trouble.
I'm planning on installing the 3 guage pack in my factory guage cluster.
Did he mount them behind the clear plastic covers, or were they removed?
hey, im thinking of getting a 3 Gauge Din Holder from your site.. i just want to make sure that they fit the 60mm apexi l2 series gauges?. they fit ok?. thinking they should :) ?
2in is 50.8mm so will not fit.
really damn.. thanx for that.. lucky i didnt buy one :santa:
any one seen and 60mm versions of the 3 gauge holder
i just bough two of these style gauges with a greddy r33 2 pod a-pillar mount. all in all a top setup. my 2 mates bought the $175 deals and we will install them tomorrow...
Edited by frozenwaffles
Thanks for your order :) If there is anything else you need please dont hesitate to ask!
We would love to see some pics of your dual gauge setup, so dont be shy to post them up :)
Cheers, and happy new year.
Steve
how much for the single din 3 gauge installed?
Hi Dan, unfortunately we dont offer an installation service on gauges im afraid.
Steve
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
