I am aiming to make my car capable of running flat 14's but have had some conflicting advice on how to do so.
Was wondering if any ppl on here had similar powered cars and if so exactly wat mods u've done to achieve this.
So far I've heard u need:
1:
Full exhast with 2 chambers dump pipe
FMIC
POD
Boost to 9PSI
2: All of above plus Z32 aiflow meter
3:All of above + PowerFC or GREDDY equivalent
Plz keep in mind i dont wanna F$%K my stock turbo so i wanna run 14flat safely without doing any damage
Can ne1 help?
https://www.sau.com.au/forums/topic/127073-14-sec-r33-gts-t/
  • Replies 43
Full turbo-back exhaust (3inch) - $1000
Replace standard panel filter with a K&N Filter - $100
Bleed valve (10-12psi)- $100
FMIC - $1000
Adjustable exhaust cam gear - $180
= $2,380 + fitting
This should give you up around 180rwkw with a healthy engine. Using decent quality roadworthy standard size tyres (225/50/16) you should be able to do consistent 13.5-14.0 sec with a 1.9-2.0sec 60ft at around 100-103mph, the rest just comes down to driver ability and how long your clutch will last.
Edit: You won't need an Apexi PowerFC, but it certainly would help and you certainly won't need a Z32 AFM (until you change turbo's atleast but by then you will also need a new fuel pump and injectors).
Edited by benm
If you run it at 12psi all day every day you may experience problems but for 14sec a few times every now and then you wont have any problems.
Your clutch will be fine.
Do a search for the Exhaust cam gear, plenty of info available including a thread I created with before and after results.
I did a 13.2 running my car the way how it is:
hardwalled circuit semis. Rock hard coilovers. lowered quite a bit, so too much negative camber affecting traction (-2.5d).
12psi. full exhaust. stainless steel magic cat. No aftermarket ecu.
twin plate clutch with lightened flywheel.
I must admit though, I am really crap at drag racing. If it wasn't for the twin plate, I woulda probably killed the stock clutch in one outing.
PS: I run 12-13 psi all day everyday, and I don't drive it easily. It is still strong after 2 years, and god knows how long or what boost the jap owner ran it on.
I don't see any problem in blowing the stock turbo. They're cheap as chips (around the 3-400 mark for an r33 turbo). I'm happy to blow it and change it myself.
Yea but u could blow ur engine in the proccess of blowing turbo, i'd be carefull
Mate as you can see in my sig, i have done a 14.04. the car is virtually stock, the mods i have are dump pipe off turbo, 3inch exhaust. thats it really. I run stock turbo, stock FMIC, stock ecu and standard boost. Ohh and that run was on shitty falkens 326's, worst tyre ever!!! well maybe not worst but damn close.
2rismo, I understand that you have extensive experience, and i've been following your progress.
Every car is different. I understand that some cars like benm's was only getting 14s with around 200rwkw. There are others like that.
I can only offer the experience I have from my car. Refer to above. With a catback, pod filter. stock boost. hardwalled circuit semis, I did a 14.01. I have a timeslip at wsid to prove it.
Then with the mods I mentioned above, I did a 13.2. My car is totally not setup at all for drag with the rock hard suspensions, lowered, way too much neg camber. But that's just what my car did. Maybe it's a freak?
I can tell it's definitely the stock turbo, because when I changed the dump, I verified that.
I call that driver ability, i'm now only doing 12.3sec with a 310+ kw gtr when I should be doing mid 11's.
Edited by benm
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
