Can someone draw the driver a diagram so he can figure out what an apex is? It seems like its an accident when he clips an apex, rather than when he misses one.
Can we confirm if its an R8? Audi races them at Le Mans, and a hillclimb seems a bit tight for a car designed to do over 370km/hr down the Mulsanne Straight. And it doesn't sound like a 3.6L twin turo V8.
It looks more like a Westfield / Radical car to me...and if it had a worked bike engine then it would swallow gears like that.
https://www.sau.com.au/forums/topic/127619-hill-climb-vid/#findComment-2358294
Don't know about all the spectators standing pretty well on the road though as he comes blasting through... couldn't think of anything more dangerous
How about Rally, where the spectators / photographers stand on the course, jumping out of the way only when the car approaches?
https://www.sau.com.au/forums/topic/127619-hill-climb-vid/#findComment-2358303
dont be too hard on the poor guy scathing! I would say he's not a pro driver, more just an owner/driver enthusiast. He does move his hand around the wheel alot which suggests to me that he hasn't had a lot of experience in prototypes or open wheelers. I didn't think he was doing too badly overall. yes he is pretty wide a lot of the time but that may be for safety as much as anything and it may be the quickest way through the course in a car like that. it certainly is an awesome hill climb course that's for sure.
https://www.sau.com.au/forums/topic/127619-hill-climb-vid/#findComment-2358386
Hey, if it was me in that thing you could probably drive another open wheeler between me and the apexes :wub:
I probably wouldn't be posting it all over the Internet though. :D
But that hillclimb looks a lot more fun than Huntley, which is the only hillclimb I've ever done. I'd love a crack in it in my car.
https://www.sau.com.au/forums/topic/127619-hill-climb-vid/#findComment-2359312
You would use a totally different line when raciong down a open road by yourself, compared to racing on a track with a need to defend a racing line.
His Class time on the day would decide if his good or not.
https://www.sau.com.au/forums/topic/127619-hill-climb-vid/#findComment-2360295
And the biggest difference between a hillclimb and a circuit is how many laps you get to do in a row :angry: this run is pretty long/lots of corners it would take a while to learn perfectly.
But after doing a few hundred laps of a track you could do it inch perfect in your sleep
https://www.sau.com.au/forums/topic/127619-hill-climb-vid/#findComment-2360695
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
