Definitely will solve your misfire. Providing of course that the coils are the problem. But 99% of the time coils are the cause of misfiring.
I had the same problem on my R33 and just recently bought splitfire coils from Lynx corporation in Erina central coast. Also put in Splitfire triple platinum spark plugs. I now have no more misfiring and much crispier throttle response. It revs a lot smoother as well.
So in my opinion worth the investment.
Paul.
Have you tested the coils?
If they are not faulty, then its a plain waste of money. Splitfires are only as good as good condition stock coils
It could is a multitude of other problems, dirty AFM, dirty connections to the coils, plugs etc etc etc
hey all
iam thinking of buying split fire coils for my rb20det will the get rid off the misfire above 4000 rpm and make it run smother.
thanks
Dan
Spend $20 and change the plugs first. 99.9% of the time misfiring is caused by plugs.
:dry: cheers :(
possibly get new plugs and run a smaller plug gap. helps firing and may make your need for coil packs go away. get a workshop to gap them if you dont know how to. i dont know how small a gap you shoud run ither sorry
correct me if im wrong anyone
splitfires are cheaper than standed coils if you shop around . i just brought a set from perfect run 580 bucks delivered to my door in 4 days from japan
Edited by mid life crisis
You paid $100 for postage?!
They are around $486 converted from YEN and they do delivery by the weight, and coil packs are 1.8KG which is ~$40 to post to Australia. Should be able to have them for $526.
I just ordered some stuff from Perfect Run, the shipping was $55 which is equivelant to 2.5KG
Just out of curiosity, if you happen to have a problem with one or more of these coil units that were imported how do you have the warranty sorted out or coils replaced?
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
