Just talked to someone at Dickson Motor Registry who confirmed all imports must go through Dickson Inspection Station. Talk to Technical Standards, they are the ones that make the rules and know whats enforceable and whats not. Unfortunately 90% of people at the shopfronts dont know the difference which is why it will get registered using a RWC from a normal mechanics.
As I said, its not uncommon for mechanics to issue RWC's and the car to be registered at a shopfront using said RWC, but that is simply because staff havent been educated properly on prcedures and processes. Whilst you could tell people it doesnt have to go over Dickson, and there is a fair chance it will slip through, at the end of the day giving out that information is wrong (especially if you piss away $38 at the mechanics to have the shopfront turn you away because it wasnt issued by the dickson inspection station).
You got through, congratulations, im certainly not going to say your rego isnt valid etc. But following the letter of the law and all rules and regulations as can be clearly read on www.rego.act.gov.au and various ACT legislation documents, all imported vehicles when transferring ownership must go via dickson pits.
Edited by Amaru
  • Replies 47
Ok, well since you guys have skylines registered in ACT do you know what i could get defected on, ill say what i think i could and let me know if you had any probs with that part.
FMIC
Air intake pipe for Pod
Fuel pump...its pretty loud.
aftermarket steering wheel
Exhaust, might need silencer
And the Diff, its a cusco LSD so very noticible.
Thats all that is visible anyway, other than that i can raise the suspension so what do you guys think.
Edited by steves180
As long as the steering wheel is on good and proper you won't have a problem with that. They just jiggled it pretty rough for my test.
The rest I can't help you with as I had an engineers cert when I went over.
my advice is to just turn up and have the check done. if they make you fix things, then get them fixed and move on.
i stressed for days about one or two things on my car - in the end they had a huge list of things that needed doing. two of them were big safety issues, too. i wouldn't have predicted the list.
good luck and let us know how you get on.
That is actually a pretty good idea, what was the process when you had to change things and go back to them?
Will do mate
they showed me the list and then stepped through it with me to make sure everything was ok. they were able to fix everything or take my car to the place to get it fixed (i.e. they took care of everything). i am not sure if that's common practice.
i've sent you a pm with what i had to change/fix. :P
I could see someone getting a huge argument with someone at teh shopfront because they have an australian delivered GTR!
Just put my aussie spec 32 through rego, no problems. (thank god for that!!) :P
Edited by aus spec 32
I just went to kaleen service centre (whatever its called) and one of the mechanics said give me a quick look now and then we can book it in....anyway he saw the FMIC and boost con. and said nope we cant touch it blah blah you have to go straight to dickson. So i guess ill take it in on monday or tuesday, im packing now lol. :)
    • The price of every automatic S2 stagea in japan has suddenly doubled
    • thanks mate, one of the reasons I even bought it to be fair.
    • I found parts on EFI Solutions webshop that seemed to be the accurate ones. I haven't gotten around to fitting the turbos back on the car yet since I still have to deal with the shitty crack in the engine block. But I'm confident that the bolts I ordered will fit. According to EFI they are also 7-16/24. The reason M11x1 got involved here is because it is apparently very similar to 7-16/24.
    • Well, to be fair to the car I've driven it daily for almost a decade now, although in that time only put on 50k, as it just recently passed 100k miles early this year. For the most part its been fine because I've been able to source parts from AUS like jacks jdm and a few places in Japan, some things like pads have been easy since 300z pads swap right in... I realize its probably at that time in its life i should find a new DD (but I rent and only have so much space, no garage) so new cars just complicate things. As it is older though, I recognize its about that time as with my '67 GTO to maybe side step and find an alternative, but if i can keep driving it... I want to.   That said, I may just look into a local shop that might be able to, problem is the mechanic I work with has limited space as a mom and pop operation, and he's a busy busy man, so id need to find out if he can keep the car in the meantime, which may or may not be practical for him. Maybe I'll just buy one off jacks jdm and get that refurbed /shrug.. just looking at options and what others may have to offer for advice on the matter. Like I said, its hard finding people around here who actually have one, I've had mine 9 and a half years and I've met 3 others, and they are all military, one was oem from 95 with 30k miles (rip that car... guy got hit after someone crossed s double yellow, totaled it)
    • I've noticed my rear springs sag a bit compared to the fronts. I have stock springs and KYB struts. The front wheels are pretty consistent in their ride height, but compared to the front wheels, one of the rears sits 20mm lower, and the other 40mm lower. This negatively affects the ground clearance, and also angles the headlights up. What are some some economical options for new springs? Or information like good spring rates, lengths  in order to find a suitable replacement etc Far from lowering the car, I'd prefer to raise it a bit to keep it ground clearance friendly.
