Last week driving my girlfriend to work from Endevour Hills to city I got onto St Kilda road, the left lane was chockers but right lane had no traffic to I went ahead doing around 50 KM/h and watching out for any cars that may try and jump into my lane... I come past this tram island and this stupid young chick starts slowly walking right across the road infront of me, turtles crawl faster!!
Anyway I slam my brakes and slightly turn the streeting wheel to the right away from the girl (bad move I know but I would of prolly bumped into her)... I then bumped the embankment roughly doing about 5 KMs an hour... I was slightly shocked at the whole situ beeped the f**k out my horn, she waved sorry to me but still seriously she had a death wish.
Anyway my concern is about the bump into the embarkment. I got out to check the right wheel shortly and saw no damage at all. I then drove without my hands on the steering wheel and the car went anywhere I pointed it to without drifting right or left. I presume that there was no damage at all as like I bumped the side doing rouhgly 5 KM/h.
Just want to be certain... I need to also rotate my back tyres upfront cos they have less tread now... will I need to balance my 4 wheels?
https://www.sau.com.au/forums/topic/127729-small-incident/
Hmm, id suggest getting it looked at - just to be certain. You dont want to be on the fwy or some road thats marked 80km/h and with a lot of turns when the steering fails.
I know what u mean, some people are idiots - they just dont know what they are doing on the roads.
https://www.sau.com.au/forums/topic/127729-small-incident/#findComment-2360474
I never bother about rotating tyres. There is no need to wear them all equally so you replace all 4 at once.
I stick by the brand of tyre that I use and always use the same one anyways. Not that ther eis a problem having different tyres on different axles.
You should be right regarding the embankment if you only hit it at 5ks. I've mounted a kerb twice at 30ks. Silly me, but i wasn't used to the tight turning circle of the skyline in the beginning.
I wouldn't have turned.
https://www.sau.com.au/forums/topic/127729-small-incident/#findComment-2360499
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
