hey there guys. i am a newbie to all this audio stuff, but i can learn very easly. anyways i am planning to do a custom boot, dash and door panels with fibre glass. was just wondering if any of yous could help a brother out and give some info on how to mould and what i should be using for best sound and strength.
thanks heaps
Gordon
https://www.sau.com.au/forums/topic/127754-custom-style/
yeah but i am in wa
Dont you have cabinet makers etc in the west?
But really, to describe how to custom mould dashes etc isnt exactly the easiest task, in fact a botched custom job will look awful.
My advice, if you dont know what you are doing, dont try to get advice in words from a forum. Seek out the help of a professional custom installer, pay for his/ her time and end up with a car that is worth showing off, not hiding in shame.
Take it from me, i've only been in the game 11yrs or so...
https://www.sau.com.au/forums/topic/127754-custom-style/#findComment-2363336
yup, of course .. build a frame then lay it with carpet or something :)
Best thing about custom - if you do it and yo dont like it change it
Worst thing about custom - if it looks shit its your own fault not someone elses
Best thing about tailor made - Will look sick in the end
Worst thing about tailor made - Sometimes costs an arm and 2 legs + you might not like bright pink fibreglass with rainbow neons
(just stating the obvious)
Look at some examples of cars dude, checkout a civic or two, normally riced up to the max, and have some sweet installs. Even go see one, eg. look in autotrader for a civic with a custom stereo and pretend to buy it and checkout what he did.
OR checkout AUTOSALON this weekend :D hint hint
Edited by Hypn0tiK
https://www.sau.com.au/forums/topic/127754-custom-style/#findComment-2363533
You deadset on fiberglass? i made an entire mdf floor in the boot of my 32, screwed the amps, wires and sub box to it then did another layer of mdf with vynal on it and it looks schmicho! much much eaiser than fibreglass...
https://www.sau.com.au/forums/topic/127754-custom-style/#findComment-2364611
https://www.sau.com.au/forums/topic/127754-custom-style/#findComment-2364613
Not sure if mods will allow an external URL, but for car audio tips and making custom pods and stuff out of fibreglass, check:
www.caraudioaustralia.com
There are plenty of tutorials on how to do it properly.
https://www.sau.com.au/forums/topic/127754-custom-style/#findComment-2366735
yeah that site is awsome, helps a lot. looks easy. and it explains a lot
https://www.sau.com.au/forums/topic/127754-custom-style/#findComment-2367546
OR checkout AUTOSALON this weekend :) hint hint
hey, how did you get the skyline badge/strip on your boot to light up? looks awesome! i assume you bought it? Where from? and how much?
https://www.sau.com.au/forums/topic/127754-custom-style/#findComment-2369175
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
