if you want any more info etc pm me are call/msg me on 0422258117
cheers
brad
-GCG/XTR T3 steel wheeled ball bearing highflowed turbo, excellent condition, 56mm wheels, rated to 450hp, good for 25psi, ran 10-16psi everyday only ran on 20psi once when i went to the strip, nearly one year/8000km old, has 10psi actuator
data label model: xtr-gtst-s1
serial no: 014464
more info check out gcg's website
http://www.gcg.com.au/Catalogue_Menu...grade_gtst.htm
Worth $1950 Looking for $700 ono
check out the pics
http://img143.imageshack.us/img143/2786/dsc00544ql0.th.jpg
http://img85.imageshack.us/img85/1175/dsc00545xu7.th.jpg
Turbo is a RB20 item, the rb25 front housing elbow pipe will not bolt up, other than that this will bolt up no problems, it has the same wheels/machining/bearings as the gcg modified rb25 turbo and yes it will bolt up to an r34 neo as they are the same bolt pattern on the elbow as the RB20 turbo
Edited by RB20/30Det_VL
https://www.sau.com.au/forums/topic/128080-fs-syd-gcgxtr-t3-highflow-450hp/
cheers
brad
serial no: 014464
check out the pics
Hi mate
Will this item fit an R34 GTT? Probably a stupid question I know but having only experienced 34's and not 33's, I jjust had to ask.
Cheers
Muz
as i remember, you can fit this onto r33, but just need to drill one of the holes larger than the other 3 on the inlet elbow, jus so that all bolts will fit proper, and just use a washer to seal it off.
i might be wrong, but can be customized..hehe
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
