i would like to go but i dont know anyone on this forum so i think i might give it a miss, plus im a p plater and cant drink any beers :) hope it al goes wel tho :)
DW if we are cruising i think alot of ppls wont be drinking
all i know is im cruising upto the big rocking horse, to be there @ 5pm to pick my daughter up so we could all cruise that way there is a big car park there ;) and then onto the whispering wall after
  • Replies 280
Posted Images
i probably will only have a few myself so ill be taking it easy. like the name tag idea, last cruise i went on couldnt work out who was who. altho i dont think my chest will pop the name tag out enough lol
Yeh Jared maybe we should have some stickers on hand so when people rock up they can write thier 'username' or 'real name' or even both and wear it........... wherever they want eg: chest or forehead!
This is not such a bad idea, as there will be a tonne of people there I don't know & just to confuse everyone I've changed my username ;) (it was Electro). Have you nominated yourself for the job Deluxe???
Ahhhhhh Crap........ Well i guess it depends on how you work the day and if i'll be there to start with(should be)! But it might pay to maybe book a room out and that way we could have this sticker pad thing at the door so people can do it them selves, because there is ALOT of people i still don't know i here too, and it would save one of us running around asking every random person if they're with SAU!
Haha it's ok, you don't have to do it ;). Not a bad suggestion though.
If anyone else know's they will be coming & can easily get ahold of a deacent labelling machine or label printer it would be handy though. Will keep this in mind if I get time.
you should add a voting option on this thread itself rather then pm. so everyone see's which one is the most favourable location. or make a new thread with a voting option.
Really if people want to come they will request a PM. I'd rather people that are actually going to come to vote, rather than letting everyone vote only for half of them not to turn up, & then the people that do turn up to complain they wanted the other joint.
I also don't want 20 unaccounted for people rocking up & then we find out we don't have enough room or something stupid. So the idea is to keep everything as in control as possible >_< . It'll save a lot of heartache for me later.
Yeah I'll leave it up to the voters to decide rather than overrule it now. The only reason I may change the venue is if we can not get in to the most popular one at close of votes. If a majority appears beforehand I will make the booking, at the moment though it's pretty even.
Oh 1 thing I forgot to point out people about the ale house. If we go there we'll be in a courtyard area as the bar will not be big enough obviously & if we have enough numbers we'll get the area to ourselves.
good show
wots every 1's thoughts on following me upto the rocking horse and then onto whispering wall
Is this a family thing? the meal etc...... my 3yrold would love to see the giant rocking horse.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
