  • Replies 50
Posted Images
even better chuck on the std BOV, they're pretty good until you start running high boost levels.
maybe i got something diff but what ever i removed to install the aftermarket BOV never made any sound. all i ever herd was the turbo whine
OMG - The flutter sound does not come from the BOV....It just means your aftermarket BOV is set too tightly and most of the air is reversing back through the turbo getting chopped up by the impeller hence the 'flutter' sound...You couldn't hear it b4 because your airbox muffled the sound.
Sure? I wanted to confirm what was making this noise the other day and watched my blow-off valve open and close repeatedly after opening the throttle small amounts and then closing it. The flutter was coming from the blow-off valve, and it makes sense from an engineering point of view.
Lowering the spring tension would allow the valve to open completely at lower pressures and not 'bounce' between open and closed. That might fix it for you.
I've currently got no BOV at all (blocked off the hole in the intake), I can still hear the psshht and then flutter. Is the sound of the air 'blowing off' just the rush of air coming back out the pod?
What i'm saying is it's not necessarily air running back through the intake (if you have a BOV). Primordial in your case it'll just be air rushing back and doing funny things :happy:. You can check for yourself though, just pop the bonnet, rev your car and see if you can feel air coming out of the filter and match it to whatever noise you hear.
Edited by govich
This is basicly what ^ said with some instructions.
Make sure car is off... Take off the blue hose from the BOV and undo the bolt with the red circle around it one revolution. Then reconect the Blue hose. Start car and test. Repeat all steps until you are satified.
Still caused from a surge buddy. Noise comes from pod and sometimes bov.
My blow-off valve bounces between open and closed (this is visually obvious), air comes out of it and this makes a fluttering noise. There is no other audible fluttering or whooshing associated with the air, from the pod or otherwise.
Flutter is NOT caused by the BOV! I had no BOV for a month, fluttered like no tomorrow... Now I've got the stock BOV back on (with some mods) and I get both the flutter and PSSSSSHHHHTTT
Jeeez; it's just a sound!
OK.
With the stock blow-off valve on, my car does not flutter. At all. Ever.
With the aftermarket atmospheric-vent blow-off valve, the car flutters on trailing throttle or after closing the throttle after light openings. I have visually confirmed this sound as coming from the blow-off valve bouncing open and closed.
If the throttle is closed after being open wide, the blow-off valve dumps completely and there is no flutter. At all. Just whoosh.
How is the noise (in my car) not coming from the blow-off valve bouncing open and closed?
I'm not posting about this again :cheers:.
I had the exact same GFB BOV and it fluttered even thbough all pipes were connected and closed off. The flutter IS due to ur BOV. Read the manuell, it says flutter at low rpm is normal, u can probably eliminate is by following the advice other guys gave u.
Edited by Sir-D
An aftermarket BOV is probably a lot tighter than your stock one. Fluttering at low RPM would occur because the blow of valve would not open at lower revs/boost, thus the air going back through the intake (as in going back against the turbines spinning direction, shopping the air), amplified by your FMIC and pod and wellah, flutter for you.
A blow of valve can help effect it, but it doesn't directly make the noise. Forgive me if it doesn't make sense, I need sleep :cheers:
More info:
http://www.nissansilvia.com/forums/index.p...60&hl=stock
Edited by ReeceR
Ok I'm going to settle this once and for all..
The fluttering you here is the pressure created by the turbo changing directions and flowing back through the turbo when the throttle snaps shut. The factory BOV's have a weak spring to let through air at idle so that fluttering does not occur. This air recirculates from the cross over pipe and goes through a pipe which is realeased in front of the turbo again. Disconnect this pipe and vent the factory BOV to atmosphere and you will create a idling problem on the car. You will NOT have a true turbo flutter created through a aftermarket BOV. The only time it will create a noise like a flutter is if the spring is stuffed in the BOV or if the BOV is created to make a similar noise to a flutter.
It sounds to me like you BOV is way too tight, loosen it off and it will fix it. You cant hear a flutter through a air box so hence why you couldnt hear it before.
guys isnt the flutter the sound the air going back and forth between the throttle body as it snaps shut off throttle and the turbo, and the sound is heard once u get a pod, stock intake u cant hear it.
there is bovs that also make that noise or similar noises but they arent compressor surge they are just noise the bov makes instead of compressor surge
hence the reason of getting a bov.
most cars with aftermarket bovs will have to set how lose or tight they are, if they are too tight u will get compressor surge, too lose and u could leak boost depending on the bov and the boost level.
generally to get it right u need to find a setting somewhere inbetween where on low psi u get the flutter because its not enough pressure to open the bov generally below 7psi or so and that on higher boost over 10psi etc the bov opens and no compressor surge, no back pressure on the turbo it keeps velocity and u dont lag as much between gear changes.
i could be wrong but i dont think i am, would like to be corrected if am.
Edited by ODessA
If i'm not wrong, the flutter is commonly caused when the air goes back into your turbo fins.
Without a BOV installed, u'll get the flutter all the time. With a BOV, you will get both the flutter ( at lower RPMs ) and most of the time u'll hear the BOV sound that's IF it's an atmospheric BOV. If it's plumback BOV, u'll hear the flutter too.
Anyone care to input their knowledge? :cheers:
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
