Hi guys, I have been meaning to do this since i signed up!
6U9000ERC33029557
Thanks in advance!
Dan
Pretty sure you put the 'R' and the 'C' around the wrong way mate. If you meant to put ECR33 029557 this is your fast mate.
Can some one do this for me?
It is supposed to be a vspec
6U9000BNR32300152
sorry mate not a vspec.
Use this link to decode it so you can see its not a vspec
http://www.users.on.net/~goofyhsk/info/chassis_plate.html
Hi again
Still working through the conversion stuff
Could you please find part numbers for
V35 5 speed auto 3.5 VIN is PV35500185 engine loom
Z33 5 speed auto 3.5 VIN JN1GAAZ33A0010030 (gave you it all, just in case) engine loom, ecu and gearbox
Z33 5 speed auto 3.5 VIN JN12AAZ33A0250072 (gave you it all, just in case) engine loom, ecu and gearbox
Regards
Edited by CeffyNSW
OK guys
Too much to ask by the sounds, my apologies.
Working through some wiring diagrams and it should be OK.
Regards
Would appreciate someone doing my v35 2004 sedan.
VIN 6U90000PV35450969. Need to know if it has viscous lsd or not?
Thanks in anticipation. Graeme
You guys should PM "chook". I cant fast v35's.
sorry guys
Can anyone tell me if KBNR32RXFS AA is a normal GTR or V-Spec?
Bought it 5 years ago as a normal GTR, but the chassis plate decoding page seems to indicate it would be a V-Spec. Not fussed either way, it has Brembo's on the front, standard Nissan callipers on the rear and a few other V-Spec pieces in it. It will always be my B-Spec (bitsa everything).
BNR32219986
Cheers :)
If you use the last 6 digits of your vin on the website i use to decode the r32 model codes it says your gtr was built between 07/1992 and 08/1992 so its not a vspec but when i type in your vin nothing comes up. I have to also put in your model code. which confirms it isnt a vspec. Strange because i havent had to do that before. :)
Here is your fast mate
Edited by babyskyline
Cool, thanks for that. I seem to recall that happening a few years ago when it was FAST'ed.
Wonder why it lacks the 7 on the end of the model code which would indicate its a normal GTR, as according to that code site a lacking number means its a V-Spec... *shrug*. It has all the V-Spec running gear and a few other 'mechanical oddities' every reputable GTR workshop I have taken it to has never seen before, so ill keep calling it my B-Spec :)
Edited by Amaru
Im really hoping im wrong but because it has the brembo's, and all the v-spec running gear as you said, and seems to have a vspec model code but has the vin of a car that was made in 1992....it might be dodgey. Im really hoping its not for your sake but it sort of sounds like someone added vspec gear and tried to pass it off as a vspec with the model code.
Well it wasnt sold to me as a V-Spec, but as a normal GTR with Brembo's so im not fussed about that (e.g. I didnt buy it because it was advertised as a V-Spec). Have attached a pic of the VIN plate, it looks real and doesnt look like it has been changed.
I wouldnt be worried about it if you didnt pay the extra for bein a "vspec". As long as your happy it should be fine. Just seems strange to have had the gear put on and a vspec model code but not be a vspec.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
