would appreciate this one getting done BCNR33008451
as much info as possible would be great
thanks
It's marked as "For the Cold Districts" which presumably means it had an optional pack for snow country (R33 experts, help me out here!)
After that, Super Fine Hard Coat and rear wiper are the only two options listed.
could I please get some help on my model codes for the 33 gtr, I'm trying to find out what exactly the car is and what it came with from factory
my model code is GGJPRQFR33ZDA-----
So far I have got:
G - 2 door
GJ - RB26DETT
P - Super Hicas 4WD
R - Right hand drive
Q - GTR
F - 5 speed manual on the floor
R33 - Model
Z - Intercooled twin turbo
D - ????
A - ????
thanks.
Added, not sure on the last two.
BNR32-312893
is this a vpsec? september 94 model
original paint colour?
Thanks guys
where do you get this program from?
Its 94 model so could only be a vspec 2 and its not.
Paint code is 326 - Crystal White
Nissan fast can be downloaded from some websites/torrent sites. Youjust have to look for it
BNV34401570
Hey mate, is this a an R34 VSpec 2 (White) ?
Trying to find what it came with etc etc
Thanks!
Its a vspec 2 and its white.
Options are
Brake upgrade
Super Fine Hard Coating
Advanced Aero System
Privacy Glass
LMRF2 (NOT SURE WHAT THAT IS)
Multi Display Meter
Rear Wiper
Edited by babyskyline
Thanks for that mate!
much appreciated
Hi,
can someone help me find out about my car?
my vin number is 6U90000ER34030470
Many thanks!!
special features:
glove box lamp
insulated uv cut glass
keyless entry
xenon headlights
sunroof
trunk finisher?
rear wiper
colour is "active red"
Edited by SkyHi_33
Anyone? please!
missed your post.
heres a screen shot, the extra little window open usualy tells me what special options came with the car however for me its only ever worked with r34's otherwise i get a bunch of characters like i got with yours :)
sorry bud..
special features:
glove box lamp
keyless entry
xenon headlights
sunroof
trunk finisher?
rear wiper
Hey mate,
one last question from me, is it possible to check whether mine is a series 2 or not? sorrie for all the trouble man. Much appreciated!
missed your post.
sorry bud..
I thought it might of just been my version of fast, oh well. Thanks anyway :)
Hey mate,
not sure how to find that out... maybe someone else on here knows?
hey guys,
can i please get a rundown of ECR33108743
i have a screen print of it that someone did for me a while ago, but it doesn't tell me the factory options and such.
also, does gts25tml mean it has the A-LSD?
cheers
Ric
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
