Hey URGENT ONE PLEASE i am buying this car tomorrow very much appreciated thanks
vin 6u9000bnr34002738
engine rb26070459a
need to know if its a real v spec 34 midnight purple
Looks like GTR/V indicates V-Spec model
LV4 paint code - not sure - is that purple?
if you could can u plz do it as soon as you can buyin this car tomorrow, and didnt know about this b4 20 minutes ago haha biggrin.gif also tenkin http://www.skylinesaustralia.com/forums/Co...;hl=colour+code check that LV4 is purple
Edited by timr32gts
that's what we need. the japanese chassis number
can't do it till late tonight, unless BundyBear can do it?
I was just playing around with my FAST as previously I had problems with some VINs not showing up but so far the last 2-3 were ok.
yeh actualy that vin number is off the compliance plate.. what about chassis number HCR32 287900
hey dude hope ya get this in time ... had PC issues think I got a Viri
cheers all
EDIT::
KH2 - Gunmetal Grey Metallic
Edited by BundyBear
hey thanks man all good matched and got my Car biggrin.gif somethin weird but on the vic rego sticker it says sedan??? on compliacne plate and that it had coupe like is a coupe any ideas
yea probably an EBSAC (Error Between Screen And Chair) error on Vic Roads behalf, seen NSW RTA do similar things, I'd give em a call n let em sort thier shit out
hey bundybear done that worked they got it all sorted that for help man.. car failed blueslip but everything was fine besides exhaust the mechanic was going on about need a standard exhaust not a stock exhuast a STANDARD exhaust so yeh gotta figure stuff out he said the exhaust was fine just for the blueslip need 2 get a standard then put mine back on which is pretty shit so gonna figure somethin out with that .. thanks for ur help but biggrin.gif
Not sure if you can do it, but here is the chassis number for my MQ Nissan Patrol. KR160739277
Need to find out which diffs have been used as there were several options and what ratio they are.
cheers
no probs there tim, think I seen a 'swap parts 4 rego' thread somewhere on SAU, might B of interest
BCNR33004468
R33 Skyline GTR that i am buying, bit of a beast :) 700+HP
PublicEnemy : my version of fast doesn't do that Series but while FAST will let you look up the std diff part no it won't give you a ratio, I'd sujest ya local 4WD club
Sorry BundyBear can't see your attachment, can you reattach please? Thanks.
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
