Top right of the screen where all the buttons are there is a white and blue one that says OP. Click it for options fitted to vehicle. A lot of older vehicles will show jibberish... newer ones will be in engrish.
Thanks Psymon, just comes up with lots of pages of Japanese.
Bis-e Bee - That VIN doesn't work in my version of FAST, but I think my data might be fairly old and may not have stags in it. Either that or Im doing something wrong. Im new to all this.
You're probably doing it right, the versions of FAST floating around on the internet are fairly dated and seem to be missing a lot of VIN data. I work for Nissan so my version of FAST gets regular updates.
Someone please FAST this one for me, I am running 64bit windows and cannot get it installed :(
NM35318296
See attachment.
See attachment.
Thanks Psymon, much appreciated. Could I also trouble you to do an options screen shot?
This one was supposedly factory fitted with "some" Nismo options, just wondering if that is genuine.
It's currently got Nismo wheels, bodykit (including rear wing), Momo steering wheel, I assume suspension too but havn't had that closer look yet.
Thanks again!
Hi all,
could someone run these part numbers in FAST and see what it comes up as (if at all)
nissan part#
98584 77F00
98584 26U00
98584 20U00
one of them hopefully should be an srs aibag module for a type x 180sx... But not having much luck so far..
Cheers guys
Edited by Yeedogga
Hi all,
nissan part#
98584 77F00
98584 26U00
98584 20U00
Cheers guys
None of those numbers worked for me. Had a quick look and there's 3 numbers for drivers airbag module to suit a type x 180sx. If you can grab me a VIN from it I can narrow it down.
Sheeeit, how do I google translate a PDF?
Well I uploaded it to this site that converts it to text so it will be easy to run through google translate easily. I'll post the link up here when it's done.
Edit: Hmm didn't end up working how I'd wanted, back to square one :(.
Edited by miguelegant
Probably better off finding the ones that correspond to your VIN and just translating those few lines rather than having a crack at 8 pages.
There should only be 4 lines that apply for each model code.
Edited by Psymon
Characters 14 - 18 (in your case HCDBA). I got really bored so i did yours.
16 Inch Aluminium Wheels
Sports Rear something (kept translating as interface or boiler... maybe spoiler??)
Sports Seats (i think) + GTS25T(more jibberish)
something about Stereo Components
Passenger Airbag
Here is the original 5 descriptions if anyone wants a crack at translating better. Not sure if the forums will display japanese characters though.
16インチアルミホイール
リヤワイパー+リヤスポイラー
ポーツシート+GTS25タイプS/S(4ドア)
コンビステレオ
助手席エアバッグ
Edited by Psymon
Sports Rear something (kept translating as interface or boiler... maybe spoiler??) Would probably be spoiler as it has one.
Sports Seats (i think) + GTS25T(more jibberish) It's a non turbo so I dunno.
Passenger Airbag Yeah
16インチアルミホイール
リヤワイパー+リヤスポイラー
コンビステレオ
助手席エアバッグ
Cheers.
    • I’m here solo don’t have any hands to help so haven’t hit it with a timing light
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
