I've been searching for the Nissan FAST software for a while now and finally found on Nissan Guild here: Nissan FAST Download
The Download, Installation, and Usage Guide for Nissan FAST is here: Download, Installating, & Using Nissan FAST
US Disc 1 (Nissan vehicles): Nissan FAST - US Disc 1
US Disc 2 (Infiniti vehicles): Nissan FAST - US Disc 2
It's the most recent 2010 edition too.
I visited Skylines Australia in my search for the Nissan FAST software and I thought it wouldn't hurt to share it with you guys either since the Nissan FAST downloads are getting pretty scare. The great thing I found out about Nissan Guild is that the Nissan FAST downloads are downloaded straight from their server in your browser (and it's lightning fast to: ~1-2mb/second), so you don't have to deal with torrents or anything else.
Hope this helps someone!
Nice first post! ;o)
hey would you happen to know the difference between type-m and gtst.m? also difference between MT and MT.F5?
I *think* all turbo-engined chassis' are MT.F5, and it's probably just a labelling thing with turbo/non-turbo too.. Not 100% sure on this though.
The turbo gearbox is stronger and has different ratios, I believe... so to distinguish it from a non-turbo chassis, they probably had to put something different.
Just a quick one if anyone can help me, the VIN is 6U9000ECR33105036
Thanks guys,
Borci88.
ECR33 105036 doesn't seem to be valid mate. It's not far off mine, which is a '96 S2... (114098)
Wanna double-check the build number?
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
