Hey guys
I'm purchasing a V35 Series 2 350GT that the dealer has said an 01/2006 model.
The complete VIN provided was:
6U9000CPV35550111
I downloaded Nissan FAST and went through installing it, but it doesn't recognise the VIN at all. Must be an old version not sure.
Would be great if someone could FAST that VIN for me!
Anyone know where I can get the last most recent copy of FAST for 'evaluation' purposes /offsite backup? :)
Hey guys
6U9000CPV35550111
My FAST covers that month/year and up of V35's... It might only cover the Japanese models, and not a locally delivered one.
could someone tell me if my r33 has abs
ECR33112916
You'll need to find the options for the Model (top right box) to find out what your options are.
If you have ABS, it should be pretty obvious under the bonnet, but if you're checking for another reason you'll need to work out the above. =-]
Found the post by Strutto from 2004:
R33 Model Codes (14-18)
Erghh... So many options...
The only one I have semi worked out is the last digit (18) which will be A if you have an Active LSD, B if you have ABS, and C if you have an Active LSD and ABS... There are heaps more options for digit 18 though...
It appears digit 14 is mainly focused on the wheel and tyre sizes...
It appears digit 15 is mainly focused on the electronic options (eg, ASCD (cruise), GT spoiler, etc)
I am unsure what digit 16 is mainly focused on...
It appears digit 17 is mainly focused on the AV options (eg, CD, MD, Stacker, etc...)
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
    • Ha ha ha, so they stopped the bearings spinning on the one you want, but then decided the crank hub should slip instead 😛   Stick to RB, at least you can work on it yourself. And now it doesn't smell of vapour   Also I still believe there's a chance your new flap doesn't "pop", as even though the engine might breath hard, it has a direct path with no restriction to the inlet, which when on boost should pull a bit of suction for you. If you do get pressure in the catch can id be very intrigued. Time to put a boost gauge on it, and a session at the track, then solid cover your vent and do another session
