I would appreciate it, if someone could do mine:
BNR32 - 301782
Hey guys! Newbie here :P
Where can I get my vin/model no decoded?
Cheers :)
Post it in here and myself or one of the other guys will post it up when we have a chance.
You can use an image host such as tinypic, photobucket, imageshack etc then grab the direct link to the image, click the little picture of a tree just over the post box and copy the link into there.
Too complicated! loll I'll try explain what my problem is...
If my JAP plates say my car is a 1994 build why does it
say the following on my Aus Approval plate?
Approval No. 14134 Category MA
Nissan AAX Skyline R33 2DR *1993*
02/02 VIN 6U90000ER33014230
AAX PTY LTD
79956
*1993*
I remember reading somewhere that under the old Low Volume scheme there was only a certain number of import plates allowable for a specified model in a specified year so to get around that they'd do the compliance paperwork as a different year. My old parts car was a 1994 model but it was complied as 1996.
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
