Can you guys run this for me please - 6U9000BNR34004830
R34 GTR V-Spec / July 1999
RB26DETT
HICAS 4WD
6 Speed
2 Door Coupe
QM1 - White
Interiour Colour = Grey..?
This car? = http://www.carsales.com.au/private/details/nissan-skyline-1999-13307108?base=&vertical=Car&cr=9&eapi=2&__N=4294963846%201216%204294963593%204294701263&num=15&silo=Stock&sort=default
  • 3 weeks later...
Yep that looks right, September 93 build, Type M, Auto, Super Clear Red Metallic(AN0)
1 option, Super fine hard coat(Paint protection)
Cheers man
One thing i am worried about the bloke that done the blueslip wrote it was a sedan on it
would that effect me in anyways
No idea, wouldn't imagine it would. Really it is a sedan..
se·dan
/siˈdan/
Noun
  1. An enclosed chair for conveying one person, carried between horizontal poles by two or more porters.
  2. An enclosed automobile for four or more people, having two or four doors.
se·dan
/siˈdan/
Noun
Thx for the help much appreciated!!
Yes, President... just trying to figure out year and motor, got 2 sets of data.... was told it was a 73, but believe its a 79.... and was told it was a 4L but believe its a 4.4L....
Anyone worked on one of these motors???? Cant find engine number on block?? lol
Had a copy of fast years ago and got my hr31 passage and gts-x to work.... just cant remember how
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
