Eoi. R33/34 Rb25 Greddy Knockoff Inlet Manifold Possibly $180ea
post-20864-1154555113.jpg Hi, autotechnica will have these in australia in about two weeks, and i was wondering if there was any interest in a group buy, i will have to give them an idea of numbers. They cant give me a price at this stage, but i am hoping that they will go for about $350+postage. The site says that they will fit a 33(side feed) and a 34 (top feed)and they appear to have the holes for both fuel rails. Just leave your name if your seriously interested and ill see what i can organise.
  • Replies 196
Posted Images
what does it say on them?
anyhoo, probably interested depend on what price you can do them for.
pretty much a bolt on except for modification of the throttle cable n shiznit? or will i need an aftermarket tb too?
Not to mention completely chopping and modifying your FMIC pipe - is there seriously that much benefit to justify the gains?
I've heard varied stories about plenums - some say they're great power-getters; others say it's all for show.
If it has provision for idle control and engine water system air bleed, I am interested in one for testing.
:P cheers :D
if sydneykid see they are worthy his purchase, put me down :P
i should go measure about how much intercooler piping id need to remove... id also need to have the BOV relocated too, yes?
PM me when ready in case i forget about this... when do you think this will go ahead?
Edited by Freddy Kruger
I would be keen to get one if you can confirm that they will take standard R33 injectors and have everything needed to fit up to the RB25 easily.
At this stage im not certain about some aspects of these, im going off what the rep told me, sorry none for rb20, although you could probably make an adapter plate.Dont know $rrp. I believe the standard throttle body will fit. It does have IAC provision, and it does have a water bleed. Will let you know when i have more details.
Wow $860 for a copy... like $1100 for a brand new Greddy genuine...
Yeah I know.. Only really interested if it's less than $500 for this group buy otherwise I'll just buy the original..
I can't see why it wouldn't fit an RB20.
OK on the idle control and water bleed.
For the guys that are following me..........
has sydneykid's question been answered?? If thats a yes put me in.
I don't know how good or bad this one is going to be.
So please don't buy it just because I am.
Remember I am buying it for testing on the R33GTST.
If it works out OK, then I will say so.
But keep in mind my success rate with aftermarket plenums is not very high ie; ZERO
:ninja: cheers :)
syd... ah for the $350 that it may cost its worth a tickle as long as everything bolts back up.
btw, not following just cautious:)
Edited by handyandy
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
