Eoi. R33/34 Rb25 Greddy Knockoff Inlet Manifold Possibly $180ea
Can somebody please post the pics up here, I cant get to ebay from work :{
If they are any good at all I think $310 is still a bargin, but then again if they are shotty then you have wasted $310...
  • Replies 196
Posted Images
Can you also confirm if these ones from the guy on Ebay will use the original throttle body and injectors - in other words can it be fitted to a standard RB25 without needing anything else apart from new intercooler piping?
These manifolds are set up to run a Q45 throttle body, and would require an adapter to fit the standard throttle body. If the group buy ever goes ahead, i can make these. My concern with getting them sent from japan is that they are $310, and then we could get hit with duty, wheras i have already found them for $319, but waiting for someone to have stock
i'd take one off the ebay one's as well for that price. but $319 is still a bargain. surely, flow test and what not has to be done and verified though doesnt it?
screw flow test i just want to be able to shut my bonnet...i just want something that can be installed using the most stock parts as possible.
im assuming im not the only one here without a q45 TB, how much for one roughly or how much for the adaptor u suggested. Perhaps if its bigger its better to put the q45 depending on price.
Got a reply from the ebay guy in japan, he said he can only post it via ems as he lives in the mountains, that means it is something like $170 postage each!
Changed my mind... I'll pass on these. I've been given a tip that the casting on these cheap GReddy copy plenums is pretty bad... They may be OK, but I suppose you get what you pay for.
im in at 170 posted if it costs me $400 to make it fit im still $$$$ in front saving money on greddy
any1 no where we can get q45 throttle bodys or a cheap alternative i know they use xf on sr20det will it work on these?
or possible a goup buy with throttle bodys as well??
another question has any1 gone to or thought about getting a price off i think its micks metal craft or something like that?? or someone like that and get a price on a custom plenum?
maybe we could souse a decent one from someone in au. by the looks of this thread there is atleast 25 people after them
i know micks motor sport wanted about $850?
Edited by SXY
I got Mick to make something for my car once. Holy shit was it expensive. Lovely work though. Couldn't fault that.
I might have a chat to him. I know him a bit. It'll never cost $300-400 though.
ok guys i found this on calaisturbo.com.au
http://www.calaisturbo.com.au/showthread.p...light=group+buy
CPC custom plenums
Are you after:
a REAL decrease in lag ?
a REAL increase in throttle response ? and
the highest flowing RB30 plenum using standard runners ?
If you answered YES to any of these questions and want the results to speak for themselves and nobody else ............ read on.
See below a dyno sheet of a RB30 with one of my plenums, 80mm throttle body, standard GT35/40, and a 1.06 exhaust housing and the results speak for themselves. Full boost, 25psi, reached by 3000rpm, this is SIMPLY UNHEARD OF.
RB30 Plenum price - $900 delivered (with exchange runners) or $900 + delivery (without exchange runners)
All plenums come complete with:
- bead blasted runners
- 5 seperate vacuum fittings for brake booster, fuel pressure regualtor, map sensor, boost guage etc etc more if you like on request
- throttle body plate to suit whatever throttle body you like (XF, Q45, LS1 etc included)
- studs, nuts and washers to fit throttle body of your choice
- logo engraved on all plenums
Extra's available are:
Polished plenum $120
XF Throttle Bodies with TPS $70 (bead blasted clean)
80mm Throttle body $400 (overall flow is up 20% on XF throttle body)
Fuel rail $120 (painted in 2 pac black)
**Discounts available for packages**
For those who want more specific info, on average, each port flows well over 200cfm @ 25" without any power porting what so ever.
All work is guaranteed and fixed free of charge and postage costs paid for.
Thanks,
Ariel
pm, email, msg or call
__________________
Fabrication of inlet manifolds and plenum chambers
Group buys from $700*
Ph: 0403 279 000
Hi there mate i can get jun style rb20det and rb25det plenums a lot bigger the size then those greddy plenums, i am working out a price with a supplier at the moment max should be $600 delivered depending on how many we order if you can get 10 people then i can probably even get a better price, pics of the plenum are below i have one and am putting it on my rb25/30. Plenum is good just needs cleaning up around the inside of the tb and runners have a look at the pics. Should take about 3 weeks till they arrive once we place order.
Regards,
Antony
Attached thumbnail(s)
This came from AM PERFORMANCE
So does the plenum above use the factory fuel rail, etc.?
Also how does the Throtte Body bolt up to the plenum as the second pic does not have a flange? Unless he makes a flange to order :D
I'll be interested if you can get one suitable for the RB20 also.
Might be an idea to start a new thread on these plenums once you have got a set supplier and a set price and group buy info etc.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
