Eoi. R33/34 Rb25 Greddy Knockoff Inlet Manifold Possibly $180ea
  • Replies 196
Posted Images
WARNING! Do not buy PLENUMS from Japanese Performance Parts..
I got mine the other day and they were useless..
HUGE CRACK IN ONE, Missing Fittings in the other, BOTH USE NA Runners so they're useless!
$2000 worth of useless plenums and now they say that it's shipping damage and refuse to refund my money??
Can you get front facing plenums for the RB20DET's?
As it is now I am in need of one URGENTLY!
Criteria for this special price unit....
You must take lots and lots and lots of photos.
You must compare the unit to a stock unit with much care given to the fitting and locations of all the lines which go into and out of the plenum.
You must fit immediately.
Preferably have a dyno chart before and after with no other mods.....
But if you are desperate... then we can work something out.
BASS OUT
BASS OUT
I'm not interested in testing as my engine is on a stand and can't really be dyno run before? and afterwards is will have more mods than just the plenum change..
NV
If you can take heaps of high quality photos and everything for us, then you might be okay....
Do we know if R32 and R33 are the same?
NV
If you all consider the pics that I posted up above to be of high quality then I will see if I am able to do the testing for you all..
I will be using the camera which took those pics so If there's no problem with those pics then I will see if I am able to test the plenums for you all..
This unit, yes.
Next unit, probably not.
Somebody has to sack up and give it a go.
Without sacrifice, there can be no advancement.
This unit, yes.
I offered to do the test including dyno runs before and after without any other mods, and have been waiting for someone to contact me about it - my car is just sitting around waiting at the moment so please let me know if you want me to be the test animal.
Bass Junky: please call me on 0414 502 250 anytime if you want to arrange it.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
