Eoi. R33/34 Rb25 Greddy Knockoff Inlet Manifold Possibly $180ea
Yee ha grandma, you are it.
$380 buys you in on the deal with a 3-5 day delivery.
$340 gives you 2 week delivery registered post
$300 gives you 4 week delivery sea freight
Easy as that.
BASS OUT
  • Replies 196
Posted Images
Remember these are special prices for the first two units, after that different pricing will apply.
Gotta be fair.
Easy as that.
BASS OUT
This price is including throttle body, cable, etc.?
I can only do two R33 plenums at the cheap price.
Gunmetal, you were way way first.
The J-spec.
You both have to PROMISE to fit them as soon as you get them and do before and after comparisons.
If you are ready with the cash, my guy is ready with the parts.
BASS OUT
Just to clarify: Bass correct me if i am wrong
No TB, no cable, no gaskets, pretty much nothing.
Just the bare plenium, which is designed for a Q45 TB, so you'll need to fabricate an adaptor plate should you want to use the rb25 TB.
  • 3 weeks later...
If anyone is interested, i can now get the manifolds originally posted in this section for $299 inc freight to sydney, fits r33 and r34, i need 10 minimum. Does anyone know if i will be liable for duty? People in #1 Adriano
#2 The Mafia
I'm in, Not sure about duty though.
Bass:
I cant do the trial thing ATM as I seem to have an air leak in my intake somewhere and the car is running like sh*t, it would not be worth me doing it as you wont get any real results until I fix the issue.
Adriano:
Its probably alreadsy been asked, but do the ones that you can get fit the standard rb25det TB?
Bass:
I will still do the trial as the leak that I have might well be in the current plenum gasket otherwise its in the piping which I have to re-run anyway. Only trouble is that you wont get a before dyno run. I will still write up a fittment guide and a dyno run after the install etc...
I will take the $380 3-5 days delivery and can start work on the install the weekend that I receive the plenum, what do you think?
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
