Alright,
I am on the market for a new ecu for my R32 GTST , main requirement is it has to be MAP, i have narrowed it down to eigther Microtech or Linkecu.
I am after your personal experience with both these Brands to help me decide on eigther unit
Cheers
Cameron
https://www.sau.com.au/forums/topic/128762-microtech-or-linkecu/
Has to be Map so can run without piping, plus my afm's on its way out :)
Mercury or Millennium Motorsports will be tuning it they both have said eigther is fine.
current mods are
higmount
t70
Front mount
Hybrid dual stage boost controller
HKS Cam's
HKS Cam Gears
Bosch 040
550cc injectors
Future plans in progress atm
Bore too 82mm
Rb26 crank and rods
Forged tomie pistons
Port and polish the head
cheers
Cameron
Edited by murrayis
If you dont want to spend Motec or autronic money - i would have thought a Apexi Power FC D -Jetro would have been a wise choice for a 32?
Link is crap and Microtec I cant comment on as Ive never used one or been in a car with one.
spend the money once and once only. go autronic. nothing but good reports and i have only ever seen great results with them. get yourself a quality tuner who knows his stuff and build up a good relationship. you ll get the power u want!
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
