they should fit, but they are not ideal by any means.
far better off with 17X9 +20 all 'round.
edit: even though it may fit, it will look like shit as it wont even come close to filling the guards out either front or rear, and the front track will actually less than stock which is not a good idea. seriously, just buy GTR offset rims.
Hello From Canada! Sorry for a slight thread highjack but I have a similar question (also posted in the offset stickey thread a little higher up)
I tried to get an answer from our Skyline forums in Canada (GTRC) but was unable to get a definate firm answer therefore I come here to ask the Skyline Pro's if these rims will fit my R32.
I have a 1990 R32 GTR..
I want to buy Volk GT-7 Rims which are 18x9 offset +12 (pcd114.3 5H) ... 245/40/18 tires
I need to know by tonight if I am going to be buying them, Will these rims Fit my GTR?? Some have told me they are too big, others have told me they were too little.. and I have also been told I will need to change the tire size and yadda yadda.. judging by the offset thread I believe they should fit but since I know nothing about wheels I'm asking for a definate answer from someone who knows better.
Thank you so very much!
Alex from Montreal :)
Edited by Ti Pit
it will be pretty close mate. I had 17X9 +20 and with 245s on they were pretty close to the edge of the guards. +12 means they will be 8mm further out so it will be pretty tight. I would say they will most likely fit, but you may need to roll the guard lip a little.
17 x 8, offset 35 for front, 17 x 9, offset 38 for rear, will a GTR32 be able to use these?
If you are goign to run different width tyres front to rear be sure that the profile of the tyres are altered accordingly to ensure that the rolling diameter is the same front to rear.
All the talk i have even heard is that the cheater attessa needs the same rollign diameter on all four corners
Would you think they would fit no problem if I get the fenders rolled? Would they fit per say if I changed tire sizes? If so what size should I aime for? I'm just worried about the front rims really, I doubt I would have any problem with the rear although it would be border line.
Thank you
If you get the fenders rolled you should be ok on the rear. Depends on how much camber you run also.
The fronts are much the same. If they foul the outside of the guard get yourself a camber kit & dial in some -ve camber. It will help your handling & pull the tyre away from the guard.
thes best option is still to just buy the right GTR size/offset rims.
go for 17X9 +20 or 18X9.5 +22 - +26 and same size and offset all round. much less hassle, and it looks tough.
fark - another thing I'm doing all wrong! :blush:
Roy: does that mean if i run the same tyres on all 4 using 17x8/+35 and 17x9/+38 rims its perfectly ok..? im still a bit confused..i have 18s on my car but i wanna have a spare set of 17inch rims for track use...265/35/18 semis are seriously expensive...however is there a huge difference in running say 255/45/17, or 235/45/17 like the ones u have and 265/35/18 semis?
Edited by J-Boy
    • This is for an RB20DET. Sorry for not including that.
    • Welp, this is where my compression lands after my rebuild. Thoughts? I have ~6 hours on the motor.
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
    • I'm a bit confused by this post, so I'll address the bit I understand lol.  Use an air compressor and blow away the guide coat sanding residue. All the better if you have a moisture trap for your compressor. You'd want to do this a few times as you sand the area, you wouldn't for example sand the entire area till you think its perfect and then 'confirm' that is it by blowing away the guide coat residue.  Sand the area, blow away the guide coat residue, inspect the panel, back to sanding... rinse and repeat.
