I just chucked in my Bilstein height adjustable shocks and super low King springs.
All in all, pretty easy job!
Here is a pic of how it sits now. I have been waiting ages to do this and I love it!!
It is rubbing in the front so I will have a look at that today. It goes in for bodywork tomorrow so I will have any guard rolling done then.
I still have to install my other suspension gear (ajd front and rear swaybars, adj camber kits, adj caster kit and rear subframe alignment kit) and get an alignment.
Has anyone had experence with what it might be rubbing on? I am not sure that it is that guard... Might be the arm and could have to get some 5mm spacers for the front. I can't even get my little finger in between the rear tyre and the guard so that will need rolling/trimming.
Anyway, here it is. Any comments welcome.
P.S. Might be an idea to have a sticky updates section so people don't have to create a new topic for somethin like this...
https://www.sau.com.au/forums/topic/129009-lowered-my-car/
Cheers guys!!
I had a look today and it is rubbing on the screws on the guard that holds the plastic inner guard on. It is also rubbing when turning on the inner guard so will have to sort it out.
I will post an update when I get the car back from the bodyshop. I am getting my front bar, bonnet, front guard, rear bar, boot lid and tail lights painted and having my boot shaved, front guards rolled and rear guards trimmed...
https://www.sau.com.au/forums/topic/129009-lowered-my-car/#findComment-2386821
yea wheels are wheels to me. my best mate had dished volk rims with a $4500 price tag but they dont look much better than a cheap set. just what i think anyways. but yea car looks sweet.
its the weight of the 2 piece wheels and the build quality, sit them next to a set of lenso copys and you would just pay the extra!.....trust me I did! and they look sweet as!.....go the VOLKS! :)
https://www.sau.com.au/forums/topic/129009-lowered-my-car/#findComment-2391043
I can see your point and it is valid but at the end of the day you cant see the wheels when your driving and they dont make the car go any better.
Its purely cosmetic so i have never been a fan of spending big on wheels for my cars, but thats just me and my 2 cents.
Dont get me wrong they do cap off a car (like Todd's) but i can think of better things to spend money on first.
Todd the car looks great cobber, must make a big difference with the handling now!!!
What have you got planned now for the beast seeing as your always doing something to it :)
https://www.sau.com.au/forums/topic/129009-lowered-my-car/#findComment-2391525
Thanks B.
Well, it is in the bodyworks at the moment like I said so it will be looking spot on when it comes out!
I now have GTR injectors and the resistor pack and a Z32 AFM so I will be looking at getting a retune.
I am tossing up whether to get Dr Drift to do it again or to go aftermarket. I am about to investigate SAFC's... Can anyone tell me if I can add the new injectors and AFM and tune it up with that or would I need to go the PFC?
I am not looking at taking it to Melb to get a tune because it is going to cost too much and I may aswel spend the cash buying something I can have tuned down here! I am thinking about getting Sam to send me another chip with a map to suit the injectors and AFM and then get the A/F ratios checked on a dyno down here. If nessecary, I could always send the ratios up to him and he can adjust it best he can...
Any help or suggestions on this would be great.
I rekon there will be a little dry period in 4 weeks... I am going to be a dad :devil:
Todd
https://www.sau.com.au/forums/topic/129009-lowered-my-car/#findComment-2391966
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
