thats a series 1 motor. series 2 have a rounder tps, and it has 2 plugs (although both not always connected).
as for the series 1.5, they weren't a true model, but just a mix match. they have a series 2 wing, series 1 interior, series 1 bodykit, and most have a series 2 motor, drivers airbag as standard.
I would add;
My old S1 had a separate ignitor and a Garret turbo, with a ceramic turbine & steel compresor
It had the half moon CAS drive on the exhaust camshaft
It had one plug on the TPS
No airbags
Our S1.5 has ignitors on the coils and a Garret turbo, with a ceramic turbine & steel compressor
It's an M spec, so it has the high rear wing, front bumper and side skirts
I don't know what CAS drive it has
It has 2 plugs on the TPS, but only 1 is connected
Drivers airbag
The S2 I used for a month had ignitors on the coils and a Hitachi turbo, with a ceramic turbine & plastic compressor
It had a star shaped CAS drive on the exhaust camshaft
It had 2 plugs on the TPS and both were connected (from memory)
Drivers and passengers airbag
:no: cheers :D
Edited by Sydneykid
Post your VIN here and someone can tell you
http://www.skylinesaustralia.com/forums/in...howtopic=128496
I know that the car has an Igniter and the afm was changer with the old rb20 one.
can any one tell me the year of the motor I can take more photos if wanted.
But he is trying to find out what engine model it is. How is knowing airbags etc. going to help to figure that out?
And RB_SANDY - WTF does it matter anyway? You should have more than enough information to work it out by now.
just because in the Rb25 Turbo Upgrade, All Dyno Results post some one says that the r33 series 1.5s are makeing the most power and I just whant no know what year it is.
Edited by RB SANDY
just because in the some one says that the r33 series 1.5s are makeing the most power and I just whant no know what year it is
You have got to be kidding me?
Should have put that in your first post so we can all say that its ridiculous.
They are so virtually the same that its pointless discussing it.
    • Hi guys, I’m new to the GTR scene. Picked up an R33 GTR earlier this year that needs a lot of love. I’ve been going through the hot side, changing all the gaskets and while it was all off I managed to score a set of -9s. It still had the stock ceramics so I was pretty happy to get the 2860s.  I live in a small country in the pacific with 0 performance car scene. No dyno’s no performance parts, let alone stock parts for a skyline. I order everything from Australia and do it myself. This means I’ll be running the stock ECU. Maybe down the track I’ll get an aftermarket set up and do a remote tune.  Will the car run -9s on stock tune safely?  I have a very heavy foot so I really hope so 😂   thanks guys
    • perfect, no rush to address the leaking bush then, it's not doing much/anything
    • I'm not sure if it will bolt up, but.... I'm reasonably sure that the ID of the runners is somewhat smaller on the NAs. So it probably wouldn't be a good match at the flange where the top and bottom meet. So that would be a reason to not do it. And the skinny runners would be the bit you're keeping, which would be a reason to no do it. You'd want the big runners if you were doing any work to swap stuff. Why not just use what you've got, like nearly everyone else who has +T'd an NA? You don't need or want the TCS throttle or other stuff that is specifically DET inlet/crossover.
    • lol already been put in temporarily 3 years ago
    • Makes sense. For actuators, if the pressure itself isn't adjustable, that would mean I'd need to think about 2 different actuators with 2 different pressures on paper in order for them to work at the same time if the turbos behave differently. So measure the difference in psi needed to move both, and then get an actuator to match that difference. Assuming I cant get rid of it by adjusting the arms.  You're exactly right, never happens in gear 1 or 2. I can occasionally get it in gear 3 if going uphill but its very small. Only ever in 4 and 5. Seems kind of backwards that one of the points of VCAM is faster spool but if it introduces shuffle then it actually slows spool down.
